ConnectX-4 Multiple lane/quad
Hoping for some configuration help. We are using a Connect-X4 card, dual port QSFP28. It is connected with a 100G CR-4 DAC cable to an Arista switch.
Image type:            FS3
FW Version:            12.28.2006
FW Release Date:       15.9.2020
Product Version:       12.28.2006
Rom Info:              type=UEFI version=14.21.17 cpu=AMD64
                       type=PXE version=3.6.102 cpu=AMD64
Description:           UID                GuidsNumber
Base GUID:             3cecef15d95ca518        4
Base MAC:              3cecef5ca518            4
Image VSD:             N/A
Device VSD:            N/A
PSID:                  SM_2001000001033
Our goal is to treat this link as 2 50G ports instead of 1 100G port.
I have changed the configuration option for NUM_OF_PF to 4, which when rebooted, resulted in the system presenting 4 physical functions.
[  356.805337] mlx5_core 0000:02:00.0 enp2s0f0np0: Link up
[  420.093327] mlx5_core 0000:02:00.1 enp2s0f1np1: Link up
[  424.132549] mlx5_core 0000:02:00.2 enp2s0f2np2: Link up
[  427.681081] mlx5_core 0000:02:00.3 enp2s0f3np3: Link up
However, from inspecting on the switch side, it seems that only ever the first quad comes up
swdp01(config-if-Et20/3)#show int Et20/1-4 status
Port       Name                                     Status       Vlan     Duplex Speed  Type         Flags Encapsulation
Et20/1     MLAG Member data connected    in Po8   full   50G    100GBASE-CR4
Et20/3                                              notconnect   1        full   50G    100GBASE-CR4
When I bounce the first split interface on the switch side, I see the pair of both PF mapped to port 1 bounce as well.
[ 1187.751725] mlx5_core 0000:02:00.0 enp2s0f0np0: Link down
[ 1187.752562] mlx5_core 0000:02:00.2 enp2s0f2np2: Link down
[ 1187.753266] bond1: (slave enp2s0f0np0): speed changed to 0 on port 1
[ 1187.755334] bond1: (slave enp2s0f0np0): link status definitely down, disabling slave
[ 1187.755340] bond1: now running without any active interface!
[ 1187.755443] br-vxlan: port 1(bond1.57) entered disabled state
[ 1198.900903] mlx5_core 0000:02:00.0 enp2s0f0np0: Link up
[ 1198.901721] mlx5_core 0000:02:00.2 enp2s0f2np2: Link up
Is there an mlxconfig or ini reconfiguration which can be done to make it so that the 2 PFs on each port are independent/different lanes of the CR-4 DAC?
Ultimately I want the card to negotiate 2 discrete 50G or even 25G links for the PFs so that we can have independent interface configuration on the switch side for each of them. How would I get the CX-4 to treat them as separate rather than mirroring state of the first PF on a port?
This is something similar to intel epct, where you can split the ports into different links, here’s an example of that tool
root@comp-1-1:~# ./epct64e -nic=1 -get
Ethernet Port Configuration Tool
EPCT version: v1.41.03.03
Copyright 2019 - 2024 Intel Corporation.
Available Port Options:
        Port                             Quad 0           Quad 1
Option  Option (Gbps)                    L0  L1  L2  L3   L4  L5  L6  L7
        2x1x100                       -> 100   -   -   -  100   -   -   -
        2x50                          ->  50   -  50   -    -   -   -   -
        4x25                          ->  25  25  25  25    -   -   -   -
Active  2x2x25                        ->  25  25   -   -   25  25   -   -
        8x10                          ->  10  10  10  10   10  10  10  10
        100                           -> 100   -   -   -    -   -   -   -
CX4LX EOL we will not support that.
