Hi
We have an issue with ConnectX®-4 Single 100Gb MCX455A-ECAT cards, that has 12V fuse (F3) blown on 3 cards
The set up is below:
Mainboard with two x16 PCIE Gen3 slots
Two MCX455A-ECAT cards installed on these two slots
Use a copper cable MCP-1600 to connect these two card together
OS: RHEL/Centos 7.3 aarch64
Test system put into a LAB with room temp around 20 degree C, Force air provided for cards with the direction from Mellanox Chip set to port, airflow speed >450 LFM.
Running iperf test or ping test for long time, and see that there were 3 cards failed with the same phenomenon that the 12V fuse F3 being burnt.
We don’t know what is the possible cause of the issue, whether:
The fuse rating is not enough to handle the Max current in some circumstance?
The specific card has power consumption higher than expected?
Or any other cause that we have not aware of??
Appreciated if one has encountered with similar issue & share the information
