hi all. i would love your feedback on a weird problem where i try to mix HDR/EDR with an FDR switch. I tried all possible cables FDR, EDR and HDR, copper and glass, but i can only get the combination to really work when i force the ports on the switch to QDR. Any other setting results in extremely weak performance (merely Megabytes/second+huge latencies)
From my understanding, IB is backwards compatible and i should be able to get a working FDR line speed right?
Am i missing something?
For all mixed fabrics to function with out any issues, all needs to be on the latest code (Switch and HCA f/w and driver as well)
In any case you have a fully supported combination, and still experiencing issues, please do not hesitate to open a NVIDIA Networking Support ticket (Valid Support Entitlement needed) so we can assist you further.
Thank you and regards,
~NVIDIA Networking Technical Support
thanks for the heads up. Yes, all HCA-s and switch are at the latest available firmware level. The matrix more or less confirmed that it should work, and it sort of does, but not all the way:
Believe it or not, but kernel 5.17.5-1 seem to have solved our problem. The Mellanox stack 5.4 or 5.5 did not as well as recent kernels, however the very latest kernel worked. Magic…
