I have a CX556-A. I’ve noticed in ConnectX-5 there is an embedded PCIe switch. I cannot see it through lspci. Is there any other way to make its information visible? Thank you.
Hello Tzang -
This is not something you would be able to see in lspci, because the lspci command only list all the PCI devices connected to your machine, without showing their properties.
Currently, the answer is there is no way to make it visible as it is internal hardware.
May I ask what you would need this information for?
thanks - steve
