ConnectX-7 200G ports dead on DGX Spark — “insufficient power on the PCIe slot (27W)” on all 4 functions, devices vanish from PCI bus after init
Hey all — hoping someone can sanity-check something weird I’m seeing.
I’ve got a DGX Spark here (board P4242, DMI-verified genuine, came via a reseller) where both ConnectX-7 chips — all four QSFP ports — are dead. Kernel 7.0.0-1019-nvidia, CX-7 firmware 28.45.4028. I also run two other Sparks on the same network and both are perfectly fine, so I’m fairly confident this is unit-specific, not config or cabling.
The failure signature is the strange part. Every single boot, all four CX-7 functions enumerate and fully initialize — mlx5 binds, E-Switch comes up, MLX5E loads, cable detect runs, everything looks healthy. A few minutes later they’re just gone from the PCI bus. No error line, no removal event, nothing at all between “working” and “missing.”
Every boot also logs this, once per CX-7 function:
Detected insufficient power on the PCIe slot (27W)
and about 15 seconds after init there are AER correctable Physical-Layer RxErr entries on both GB10 root complexes (10de:22ce).
Here’s the kicker: the journal still has the unit’s very first power-on — a 22-second factory QA boot from Feb 5 2026 — and all four power warnings are already in it. Apt history and installer stamps agree there were zero boots between that QA boot and my onboarding, so as far as I can tell the fault shipped with the unit. Things I’ve ruled out: no NIC/driver/BIOS packages in any apt update window, fwupd is empty, multiple full power cycles (including wall-unplug) behave identically every boot, and the blank DMI serials turn out to be normal factory behavior — my two healthy Sparks are blank too.
So my questions:
  1. What is the CX-7 slot power budget on GB10 — is 27W per slot expected, or is that a fault threshold?
  2. Is there a known condition where CX-7 functions init fine and then remove themselves from the bus? I’m curious whether this could be power management rather than raw hardware failure.
  3. Any recovery worth trying before I write the ports off — nvfwupd / mlxfwreset, a reflash of 28.45.4028, BIOS setting?
Happy to paste full journal excerpts (init → RxErr → vanish) if useful.
Do you have QSFPs connected to any of the ports?
no qsfp was ever seated on this unit — it ran standalone (GPU over the regular NIC), and the ring cabling was planned for after we found this. but cable state is moot here anyway: the connectx-7 functions initialize clean with nothing connected, then the whole chip vanishes from the pci bus a few minutes later. cable-detect completes normally during init, the 27W warnings hit, devices gone. and the fault is already in the unit’s very first power-on — a 22-second factory QA boot from feb 5, still in the journal — so no cable was ever near the ports when it started. nothing plugged in explains it, and nothing plugged in would have prevented it.
27w dmesg warning = normal
These interfaces are hotplug, they activate when you conect a qsfp / directattach cable.
(he is going to say just plug it in) i didnt think i had a spare cable but i found one, and yes it works.. should have tried that first
final update — resolved, and it was our error, not a hardware fault.
@giles8’s question was the right prompt: we seated a dac and the ports came up. what we measured across three sparks:
  • the “Detected insufficient power on the PCIe slot (27W)” message shows on every unit we run (3/3), healthy ones included — driver reacting to SlotPowerLimit 0W on the GB10 x4 link, benign, as covered in the older “PCIe power related and PCIe AER errors” thread.
  • with no cable seated, the endpoints are removed from the pci bus ~15s after boot on all three units — that’s the cx7 power-save feature (dgx-spark-mlnx-hotplug package, MTKP0001 hotplug driver). missing NICs in lspci on an uncabled spark = normal.
  • with a cable seated: all four functions stay up and train. we pushed 90.9 Gb/s rdma write through a loopback dac to confirm the datapath end to end. cable insertion at runtime re-enumerates the endpoints, no reboot needed (mtk-hotplug-handler.sh does the same manually, ~18W swing).
apologies for the noise — the original post read like a hardware fault and it was a misdiagnosis on our side: we checked the suspect unit uncabled and the healthy ones cabled. leaving this thread up for anyone grepping the same log lines.
