Hello
We are running a benchmark that multiplexes a single ConnectX-7 across a number of KVM guests using SR-IOV, with each VF passed through to a guest via VFIO. We fix the total core budget at 32 (the maximum per socket on our setup) and vary the number of VMs from 1 to 16, dividing the cores equally (e.g., assigning 32/N vCPUs) and using a dedicated SR-IOV Virtual Function for each VM. We run one iperf network flow on each core, so 32 aggregated network flows over N VMs. We report aggregate throughput across all VMs. We have been seeing some serious total throughput degradation as the number of VFs (and therefore guests) increases, specifically the RX throughput (when VMs run as receiver). In the RX case, for a single guest the throughput is 400 Gb/s. As we double the guest count (which requires more VFs to be created), we see the RX throughput drop by around half (400 → 200 → 100 → 50 → ect.). Before we draw any conclusions from our measurements, we would like a sanity check on whether our NIC-side configuration is the intended way to do this.
We are separately auditing our host CPU/NUMA/VM sizing, so this question is only about the NIC and eswitch configuration.
Environment
| NIC | ConnectX-7 MCX75310AAS-NEA (15b3:1021), single-port 400GbE OSFP, PCIe 5.0 x16, PF at 0000:98:00.0 (netdev ens1np0) |
| Firmware | 28.46.1006 (MT_0000000838) |
| Host OS / kernel | Ubuntu 22.04, vanilla Linux 6.12.9 |
| Driver | In-tree mlx5_core for both host and guest — not the DOCA/OFED. MFT 4.30.1 for management. |
| Hypervisor | QEMU 10.0 + libvirt, VFIO passthrough via IOMMUFD |
| Host IOMMU | intel_iommu=on,sm_on iommu.strict=1 (always enabled — required for VFIO passthrough) |
| VFs | One VF per guest. sriov_totalvfs = 16 |
| Guest Kernel | vanilla 6.12.9 with intel_iommu=off |
Host Config
Make sure the PF is bound to
mlx5_core(it is not left undervfio-pci). -
Destroy any existing VFs, then switch the eswitch to switchdev:
echo 0 > /sys/bus/pci/devices/0000:98:00.0/sriov_numvfs
devlink dev eswitch set pci/0000:98:00.0 mode switchdev
- Create N VFs:
echo N > /sys/bus/pci/devices/0000:98:00.0/sriov_numvfs
- Bind every VF to
vfio-pcifor passthrough (PF stays onmlx5_core). Each VF’s BDF is
resolved from/sys/bus/pci/devices/0000:98:00.0/virtfn<i>, since with more than 7 VFs
ARI numbering places them at98:01.0,98:01.1, … rather than continuing98:00.x:
echo 1 > /sys/module/vfio_pci/parameters/enable_sriov
echo <vf-bdf> > /sys/bus/pci/drivers/mlx5_core/unbind
echo vfio-pci > /sys/bus/pci/devices/<vf-bdf>/driver_override
echo <vf-bdf> > /sys/bus/pci/drivers_probe
- Give the VFs external connectivity by putting the PF uplink and all VF representors
(pf0vf0…pf0vf<N-1>) into a Linux bridge, moving the PF’s IP onto the bridge:
ip link add name br-data type bridge
ip link set br-data mtu $PF_MTU
ip link set ens1np0 master br-data
ip link set <repN> mtu $PF_MTU
ip link set <repN> master br-data
ip link set <repN> up
ip link set br-data up
No VF rate limits, VF MAC assignments, VLANs, or QoS settings are applied. MTU is 4000 end to end.
Guest Config
Each guest gets exactly one VF, passed through with IOMMUFD:
-object iommufd,id=iommufd0
-device intel-iommu,intremap=on,caching-mode=on,x-scalable-mode=on,x-flts=on
-device vfio-pci,host=<vf-bdf>,id=hostdev0,iommufd=iommufd0
Inside the guest the VF comes up under mlx5_core as a normal netdev with a static IP in the
same subnet as the PF uplink.
Questions
Expected per-VF scaling. For a single-port ConnectX-7 with N VFs each driven by an independent guest, are there known per-VF resource limits (steering/flow-table entries, completion queues, cache/context resources) that would cause aggregate throughput to fall as N grows, independent of host CPU?
switchdev vs. legacy. For pure VF passthrough to VMs, with no OVS/tc offload rules and no SmartNIC/DPU involvement, is switchdev the right eswitch mode, or should we simply stay in
legacymode? -
VF driver choice. Is there any functional or performance difference between binding VFs to
vfio-pciversusmlx5_vfio_pcifor this use case? We currently usevfio-pci. -
Firmware-level settings. Beyond
SRIOV_EN=1andNUM_OF_VFS=N, are theremlxconfigparameters we should be setting when a single PF is shared by many VFs? For example anything affecting per-VF resources, steering entries, or BAR sizing? ShouldNUM_OF_VFSbe set to exactly the number we use, or is leaving it at the maximum harmless?
Happy to attach mlxconfig -d <dev> q, ethtool -i, devlink dev eswitch show, devlink resource show, and dmesg output if that helps. Thanks in advance.
