ConnectX-7 Support with 800G Based OSFP but running at 400G Speed
I have a ConnectX-7 card - MCX75310AAS-NEAT. It has a single OSFP port running at 4X100G speeds.
FS Suggests pairing this card with 400GBASE-SR4 OSFP Flat Top PAM4
But, I already have 2 OSFP with 8X100G 800GBASE 2xSR4/SR8 OSFP Finned Top. Can I use the same for CX-7.
Basically only using one SR4 port of the 800G OSFP I will connect MLNX CX-7 with another MLNX CX-7.
Will this work?
Anyone here has worked with the same and found any issues?
Thank you,
Best Regards
Hi Abhishek!
Yes, you should be able to use your existing 800GBASE 2xSR4/SR8 OSFP Finned Top transceivers with your ConnectX-7 cards.
Your ConnectX-7 has a single OSFP port running at 4x100G, and your 800G transceivers have 8x100G SR4 ports. You’ll just be using 4 of those 8 available 100G lanes - think of it like using half the capacity of a larger pipe. The OSFP form factor is the same, so they should connect.
If you face any issues please feel free to open a case with Enterprise Support
Thanks,
Ilan.
Disagree. OSFP finned top needs to go into switch side, OSFP flat top will go into the NIC side. Found out the hard way. See OSFP Finned and Flat Top The 400G and 800G Experience - ServeTheHome
