Hello. Excuse me for the late reply, but I did not have access to the cluster during the previous days.
Here is the dmesg output, starting from the moment we unplugged and re-plugged the cable.
[Wed May 27 11:44:18 2026] mlx5_core 0000:01:00.0: Port module event: module 0, Cable unplugged
[Wed May 27 11:44:18 2026] mlx5_core 0002:01:00.0: Port module event: module 0, Cable unplugged
[Wed May 27 11:44:18 2026] mlx5_core 0002:01:00.0 enP2p1s0f0np0: Link down
[Wed May 27 11:44:18 2026] mlx5_core 0000:01:00.0 enp1s0f0np0: Link down
[Wed May 27 11:44:18 2026] mlx5_core 0002:01:00.0 mlx5_2: Port: 1 Link DOWN
[Wed May 27 11:44:18 2026] mlx5_core 0000:01:00.0 mlx5_0: Port: 1 Link DOWN
[Wed May 27 11:44:19 2026] mlx5_core 0000:01:00.0: E-Switch: Unload vfs: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:19 2026] mlx5_core 0000:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:25 2026] mlx5_core 0000:01:00.0: Port module event: module 0, Cable plugged
[Wed May 27 11:44:25 2026] mlx5_core 0002:01:00.0: Port module event: module 0, Cable plugged
[Wed May 27 11:44:25 2026] mlx5_core 0000:01:00.0 enp1s0f0np0: Link up
[Wed May 27 11:44:25 2026] mlx5_core 0002:01:00.0 enP2p1s0f0np0: Link up
[Wed May 27 11:44:25 2026] mlx5_core 0002:01:00.0 mlx5_2: Port: 1 Link ACTIVE
[Wed May 27 11:44:27 2026] mlx5_core 0000:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:28 2026] mlx5_core 0000:01:00.0: E-Switch: cleanup
[Wed May 27 11:44:28 2026] mlx5_core 0000:01:00.1: E-Switch: Unload vfs: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:28 2026] mlx5_core 0000:01:00.1: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:38 2026] mlx5_core 0000:01:00.1: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:38 2026] mlx5_core 0000:01:00.1: E-Switch: cleanup
[Wed May 27 11:44:39 2026] mlx5_core 0002:01:00.0: E-Switch: Unload vfs: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:39 2026] mlx5_core 0002:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:48 2026] mlx5_core 0002:01:00.0: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:48 2026] mlx5_core 0002:01:00.0: E-Switch: cleanup
[Wed May 27 11:44:49 2026] mlx5_core 0002:01:00.1: E-Switch: Unload vfs: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:49 2026] mlx5_core 0002:01:00.1: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:57 2026] mlx5_core 0002:01:00.1: E-Switch: Disable: mode(LEGACY), nvfs(0), necvfs(0), active vports(0)
[Wed May 27 11:44:58 2026] mlx5_core 0002:01:00.1: E-Switch: cleanup
[Wed May 27 11:44:58 2026] cx7-pcie-hotplug MTKP0001:00: Cable removal
[Wed May 27 11:44:58 2026] pcieport 0000:00:00.0: AER: Correctable error message received from 0000:00:00.0
[Wed May 27 11:44:58 2026] pcieport 0002:00:00.0: AER: Correctable error message received from 0002:00:00.0
[Wed May 27 11:44:58 2026] pcieport 0000:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[Wed May 27 11:44:58 2026] pcieport 0000:00:00.0: device [10de:22ce] error status/mask=00000001/0000e000
[Wed May 27 11:44:58 2026] pcieport 0000:00:00.0: [ 0] RxErr (First)
[Wed May 27 11:44:58 2026] pcieport 0002:00:00.0: PCIe Bus Error: severity=Correctable, type=Physical Layer, (Receiver ID)
[Wed May 27 11:44:58 2026] pcieport 0002:00:00.0: device [10de:22ce] error status/mask=00000001/0000e000
[Wed May 27 11:44:58 2026] pcieport 0002:00:00.0: [ 0] RxErr (First)
[Wed May 27 11:45:02 2026] cx7-pcie-hotplug MTKP0001:00: Cable plugin
[Wed May 27 11:45:03 2026] pcieport 0000:00:00.0: AER: Multiple Correctable error message received from 0000:ff:1f.7 (no details found
[Wed May 27 11:45:03 2026] pcieport 0000:00:00.0: AER: Multiple Uncorrectable (Fatal) error message received from 0000:ff:1f.7 (no details found
[Wed May 27 11:45:03 2026] pcieport 0002:00:00.0: AER: Multiple Correctable error message received from 0002:ff:1f.7 (no details found
[Wed May 27 11:45:03 2026] pcieport 0002:00:00.0: AER: Multiple Uncorrectable (Fatal) error message received from 0002:ff:1f.7 (no details found
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: BAR 0 [mem 0x00000000-0x01ffffff 64bit pref]
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: ROM [mem 0x00000000-0x000fffff pref]
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: PME# supported from D3cold
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: VF BAR 0 [mem 0x00000000-0x000fffff 64bit pref]
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: VF BAR 0 [mem 0x00000000-0x007fffff 64bit pref]: contains BAR 0 for 8 VFs
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: Adding to iommu group 7
[Wed May 27 11:45:05 2026] pcieport 0000:00:00.0: Max Payload Size set to 512/ 512 (was 512), Max Read Rq 512
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: Max Payload Size set to 512/ 512 (was 128), Max Read Rq 512
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: BAR 0 [mem 0x00000000-0x01ffffff 64bit pref]
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: ROM [mem 0x00000000-0x000fffff pref]
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: PME# supported from D3cold
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: VF BAR 0 [mem 0x00000000-0x000fffff 64bit pref]
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: VF BAR 0 [mem 0x00000000-0x007fffff 64bit pref]: contains BAR 0 for 8 VFs
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: Adding to iommu group 8
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: Max Payload Size set to 512/ 512 (was 512), Max Read Rq 512
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: Max Payload Size set to 512/ 512 (was 128), Max Read Rq 512
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: BAR 0 [mem 0x7500000000-0x7501ffffff 64bit pref]: assigned
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: BAR 0 [mem 0x7502000000-0x7503ffffff 64bit pref]: assigned
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: ROM [mem 0x67100000-0x671fffff pref]: assigned
[Wed May 27 11:45:05 2026] pci 0000:01:00.0: VF BAR 0 [mem 0x7504000000-0x75047fffff 64bit pref]: assigned
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: ROM [mem 0x67200000-0x672fffff pref]: assigned
[Wed May 27 11:45:05 2026] pci 0000:01:00.1: VF BAR 0 [mem 0x7504800000-0x7504ffffff 64bit pref]: assigned
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: enabling device (0000 -> 0002)
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: firmware version: 28.45.4028
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: 126.028 Gb/s available PCIe bandwidth (32.0 GT/s PCIe x4 link)
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: Rate limit: 127 rates are supported, range: 0Mbps to 195312Mbps
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: E-Switch: Total vports 10, per vport: max uc(128) max mc(2048)
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: Flow counters bulk query buffer size increased, bulk_query_len(8)
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: mlx5_pcie_event:325:(pid 928): PCIe slot power capability was not advertised.
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: mlx5e: IPSec ESP acceleration enabled
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0 enhanced)
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.0 enp1s0f0np0: renamed from eth0
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.1: enabling device (0000 -> 0002)
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.1: firmware version: 28.45.4028
[Wed May 27 11:45:05 2026] mlx5_core 0000:01:00.1: 126.028 Gb/s available PCIe bandwidth (32.0 GT/s PCIe x4 link)
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: Rate limit: 127 rates are supported, range: 0Mbps to 195312Mbps
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: E-Switch: Total vports 10, per vport: max uc(128) max mc(2048)
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: Flow counters bulk query buffer size increased, bulk_query_len(8)
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: Port module event: module 1, Cable unplugged
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: mlx5_pcie_event:325:(pid 11): PCIe slot power capability was not advertised.
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: mlx5e: IPSec ESP acceleration enabled
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.0 enp1s0f0np0: Link down
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0 enhanced)
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1 enp1s0f1np1: renamed from eth0
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: BAR 0 [mem 0x00000000-0x01ffffff 64bit pref]
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: ROM [mem 0x00000000-0x000fffff pref]
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: PME# supported from D3cold
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: VF BAR 0 [mem 0x00000000-0x000fffff 64bit pref]
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: VF BAR 0 [mem 0x00000000-0x007fffff 64bit pref]: contains BAR 0 for 8 VFs
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: Adding to iommu group 10
[Wed May 27 11:45:06 2026] pcieport 0002:00:00.0: Max Payload Size set to 512/ 512 (was 512), Max Read Rq 512
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: Max Payload Size set to 512/ 512 (was 128), Max Read Rq 512
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: [15b3:1021] type 00 class 0x020000 PCIe Endpoint
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: BAR 0 [mem 0x00000000-0x01ffffff 64bit pref]
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: ROM [mem 0x00000000-0x000fffff pref]
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: PME# supported from D3cold
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: VF BAR 0 [mem 0x00000000-0x000fffff 64bit pref]
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: VF BAR 0 [mem 0x00000000-0x007fffff 64bit pref]: contains BAR 0 for 8 VFs
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: Adding to iommu group 11
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: Max Payload Size set to 512/ 512 (was 512), Max Read Rq 512
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: Max Payload Size set to 512/ 512 (was 128), Max Read Rq 512
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: BAR 0 [mem 0x3d00000000-0x3d01ffffff 64bit pref]: assigned
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: BAR 0 [mem 0x3d02000000-0x3d03ffffff 64bit pref]: assigned
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: ROM [mem 0x5d100000-0x5d1fffff pref]: assigned
[Wed May 27 11:45:06 2026] pci 0002:01:00.0: VF BAR 0 [mem 0x3d04000000-0x3d047fffff 64bit pref]: assigned
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: ROM [mem 0x5d200000-0x5d2fffff pref]: assigned
[Wed May 27 11:45:06 2026] pci 0002:01:00.1: VF BAR 0 [mem 0x3d04800000-0x3d04ffffff 64bit pref]: assigned
[Wed May 27 11:45:06 2026] mlx5_core 0002:01:00.0: enabling device (0000 -> 0002)
[Wed May 27 11:45:06 2026] mlx5_core 0002:01:00.0: firmware version: 28.45.4028
[Wed May 27 11:45:06 2026] mlx5_core 0002:01:00.0: 126.028 Gb/s available PCIe bandwidth (32.0 GT/s PCIe x4 link)
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.0: Port module event: module 0, Cable plugged
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.1: mlx5_pcie_event:329:(pid 2144): Detected insufficient power on the PCIe slot (27W).
[Wed May 27 11:45:06 2026] mlx5_core 0000:01:00.0: mlx5_pcie_event:329:(pid 928): Detected insufficient power on the PCIe slot (27W).
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0: Rate limit: 127 rates are supported, range: 0Mbps to 195312Mbps
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0: E-Switch: Total vports 10, per vport: max uc(128) max mc(2048)
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0: Flow counters bulk query buffer size increased, bulk_query_len(8)
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0: Port module event: module 0, Cable plugged
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0: mlx5_pcie_event:329:(pid 928): Detected insufficient power on the PCIe slot (27W).
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0: mlx5e: IPSec ESP acceleration enabled
[Wed May 27 11:45:07 2026] mlx5_core 0000:01:00.1 enp1s0f1np1: Link down
[Wed May 27 11:45:07 2026] mlx5_core 0000:01:00.0 enp1s0f0np0: Link up
[Wed May 27 11:45:07 2026] mlx5_core 0000:01:00.0 mlx5_0: Port: 1 Link ACTIVE
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0 enhanced)
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0 enP2p1s0f0np0: renamed from eth0
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: enabling device (0000 -> 0002)
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: firmware version: 28.45.4028
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: 126.028 Gb/s available PCIe bandwidth (32.0 GT/s PCIe x4 link)
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: Rate limit: 127 rates are supported, range: 0Mbps to 195312Mbps
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: E-Switch: Total vports 10, per vport: max uc(128) max mc(2048)
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: Flow counters bulk query buffer size increased, bulk_query_len(8)
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: Port module event: module 1, Cable unplugged
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: mlx5_pcie_event:329:(pid 2328): Detected insufficient power on the PCIe slot (27W).
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0 enP2p1s0f0np0: Link up
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.1: mlx5e: IPSec ESP acceleration enabled
[Wed May 27 11:45:07 2026] mlx5_core 0002:01:00.0 mlx5_2: Port: 1 Link ACTIVE
[Wed May 27 11:45:08 2026] mlx5_core 0002:01:00.1: MLX5E: StrdRq(1) RqSz(8) StrdSz(2048) RxCqeCmprss(0 enhanced)
[Wed May 27 11:45:08 2026] mlx5_core 0002:01:00.1 enP2p1s0f1np1: renamed from eth0
[Wed May 27 11:45:08 2026] mlx5_core 0002:01:00.1 enP2p1s0f1np1: Link down
Right before the removal, we had ran the test at ~200Gbps, and after this change it fell down to 25Gbps.
(The insufficient/27W warning appeared even before removing the cable, when we were still able to achieve the 200Gbps speed…)
