ConnectX-8 C8180 not support loopback -RM (Rx-to-TX)?
I’ve used loopback remote configuration in the past on CX7 (and CX6 too IIRC), so I just expected it to work for CX8 but no traffic appears to be going back out the module/cable TX lanes.
I’ve tried searching nvidia’s docs on C8180, release notes, forums etc but I don’t see anyone reporting successful usage of this config with CX8 nor anything explicitly stating that CX8 NICS do not support this loopback configuration.
I did see the note that: “Remote loopback is supported for 25G/50G per lane speed” but this seemed like it might have been written in mind for previous gen cards where the loopback RM config was not supported for lower rates (10G & lower), not higher (100G & greater per lane).
Tried reconfiguring multiple times, FW/drivers updated, FW reset.
This same server has CX7 NICs with loopback -RM working currently as well.
Thanks for your question.
In order to assist you with this issue, we’ll need to collect more hardware and software information from your system. This will require opening a new support case, and it will be handled according to the entitlement.
To Create a New Enterprise Support Case Please Use One of the Following Methods
  1. Log in and Create a Case in the Enterprise Support Portal
    AppHub UI
    This is recommended and will provide the fastest response
  2. Call your Regional Enterprise Support Number
    Find your regional phone numbers:
    NVIDIA Enterprise Customer Support
  3. Create a Case Without a Login
    EnterpriseSupport
    Can be used to check warranty status
    Recommended to reset login passwords
    Requires validation and may increase time to respond
Thanks,
Anatoly
