Does Mellanox has plan to support following DPDK API’s for ConnectX cards?
int rte_eth_timesync_enable (uint16_t port_id)
int rte_eth_timesync_disable (uint16_t port_id)
int rte_eth_timesync_read_rx_timestamp (uint16_t port_id, struct timespec *timestamp, uint32_t flags)
int rte_eth_timesync_read_tx_timestamp (uint16_t port_id, struct timespec *timestamp)
int rte_eth_timesync_adjust_time (uint16_t port_id, int64_t delta)
int rte_eth_timesync_read_time (uint16_t port_id, struct timespec *time)
int rte_eth_timesync_write_time (uint16_t port_id, const struct timespec *time)
Hi Arjun,
Thank you for posting your query on NVIDIA Community.
I would like to inform that a Feature Request will be needed to check on the feasibility of support for the above API’s. This will require an active entitlement as well as business/technical justification to implement the same.
However, currently, we do have support for HW Timestamping and customers need to enable offloads when instantiating the DPDK Application via → https://doc.dpdk.org/guides-24.03/nics/features.html#timestamp-offload
If there an active entitlement/support contract in place, please do not hesitate to open a support ticket by emailing enterprisesupport@nvidia.com
For contracts, please reach out to Networking-Contracts@nvidia.com
Thanks,
Namrata.
Does Nvidia ConnectX-5/6 has any plan to support RTE_FLOW_ITEM_TYPE_RAW?
