Dear Support,
card infos at end of email.
There appears to be a huge performance issue on mixed UDP/TCP using symmetric load-balancing accross multiple workers. We are using the option “rxq_cqe_comp_en=4”
E.g. using default test-pmd on a DPDK v20.11 or newer :
sudo ./dpdk-testpmd -n 8 -l 4,6,8,10,12,14,16,18,20 -a 0000:4b:00.0,rxq_cqe_comp_en=4 -a 0000:4b:00.1,rxq_cqe_comp_en=4 – --forward-mode=mac --rxq=8 --txq=8 --nb-cores=8 --numa -i -a --disable-rss
and configuring:
flow create 0 ingress pattern eth / ipv4 / tcp / end actions rss types ipv4-tcp end queues 0 1 2 3 4 5 6 7 end key 6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A / end
flow create 0 ingress pattern eth / ipv4 / udp / end actions rss types ipv4-udp end queues 0 1 2 3 4 5 6 7 end key 6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A / end
flow create 1 ingress pattern eth / ipv4 / tcp / end actions rss types ipv4-tcp end queues 0 1 2 3 4 5 6 7 end key 6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A / end
flow create 1 ingress pattern eth / ipv4 / udp / end actions rss types ipv4-udp end queues 0 1 2 3 4 5 6 7 end key 6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A6D5A / end
will see significant packet drops at a load > 50 Gbps on any type of mixed UDP/TCP traffic. E.g.
Whenever those packet drops occur, I see those in the xstats as “rx_phy_discard_packets”
On the other hand using a TCP-or UDP-only traffic profile perfectly scales up to 100Gbps w/o drops.
Thanks for your help!
Tobias
ConnectX6DX
<Devices>
<Device pciName="0000:4b:00.0" type="ConnectX6DX" psid="DEL0000000027" partNumber="0F6FXM_08P2T2_Ax">
<Versions>
<FW current="22.31.1014" available="N/A"/>
<PXE current="3.6.0403" available="N/A"/>
<UEFI current="14.24.0013" available="N/A"/>
</Versions>
<MACs Base_Mac="b8cef6xxxxxx" />
<GUIDs Base_Guid="b8cef6xxxxxx" />
<Status>No matching image found</Status>
<Description>Mellanox ConnectX-6 Dx Dual Port 100 GbE QSFP56 Network Adapter</Description>
</Device>
<Device pciName="0000:98:00.0" type="ConnectX6DX" psid="DEL0000000027" partNumber="0F6FXM_08P2T2_Ax">
<Versions>
</Versions>
<GUIDs Base_Guid="b8cefxxxxxx" />
</Device>
</Devices>
