This is a nearly trivial kernel from an implementation of John Conway’s Game of Life.
Each pixel reads its neighbors and sets itself to either cyan or white. It works fine, as is.
The catch: I can’t set the color to anything known at compile time. It generates a runtime
error. This happens only inside a conditional. See the commented line below.
Any ideas?
-Robert
[codebox]
const sampler_t mysampler =
CLK_NORMALIZED_COORDS_FALSE|CLK_ADDRESS_CLAMP_TO_EDGE|CLK_FI
LTER_NEAREST;
__kernel void flip(__read_only image2d_t iimage, __write_only image2d_t oimage)
unsigned int x = get_global_id(0);
unsigned int y = get_global_id(1);
uint4 mycolor, myvalue;
const uint4 cyan = (uint4)(0,128,128,0);
const uint4 white = (uint4)(255,255,255,0);
mycolor = read_imageui(iimage,mysampler,(int2)(x,y));
myvalue = read_imageui(iimage,mysampler,(int2)(x,y-1));
myvalue += read_imageui(iimage,mysampler,(int2)(x,y+1));
myvalue += read_imageui(iimage,mysampler,(int2)(x-1,y));
myvalue += read_imageui(iimage,mysampler,(int2)(x+1,y));
myvalue += read_imageui(iimage,mysampler,(int2)(x-1,y-1));
myvalue += read_imageui(iimage,mysampler,(int2)(x+1,y-1));
myvalue += read_imageui(iimage,mysampler,(int2)(x-1,y+1));
myvalue += read_imageui(iimage,mysampler,(int2)(x+1,y+1));
// A change of this assignment to anything known at compile time,
// e.g., mycolor = cyan; or mycolor=(uint4)(cyan.xyz,0); will generate an error.
if(myvalue.x < 2255 || myvalue.x > 3255) mycolor=(uint4)(cyan.xyz,myvalue.w);
if(myvalue.x == 3*255) mycolor = (uint4)(white.xyz,myvalue.w);
write_imageui(oimage,(int2)(x,y),mycolor);
[/codebox]
