Hi: below 2 versions are of same performance. 1st I think using constant mem, 2nd using global mem. How’s that 8kbytes cache/ multiprocessor doing? Thanks!
version1:
__constant__ int* c_idata;
__constant__ int* c_odata;
void
runTest( int argc, char** argv)
int nR = 1024*1024*16;
int* h_idata = (int*)malloc( sizeof(int) * nR);
CUDA_SAFE_CALL( cudaMalloc( (void**) &c_idata, sizeof(int) * nR));
CUDA_SAFE_CALL( cudaMemcpy( c_idata, h_idata, sizeof(int) * nR, cudaMemcpyHostToDevice) );
CUDA_SAFE_CALL( cudaMalloc( (void**) &c_odata, sizeof(int) * nR));
dim3 Dg(128, 1, 1);
dim3 Db(256, 1, 1);
testKernel<<<Dg, Db>>>( c_idata, c_odata, nR);
__global__ void
testKernel(int* c_idata, int* c_odata, const int nR)
int bx = blockIdx.x;
int tx = threadIdx.x;
int blockSize = nR / gridDim.x;
int loopTimes = blockSize/blockDim.x;
int dataIdx;
for( int i = 0; i < loopTimes; i++ )
dataIdx = blockSize * bx + i * blockDim.x + tx;
for( int j = 0; j < 1023; j++ )
c_idata[dataIdx + 1] = c_idata[dataIdx];
c_odata[dataIdx] = c_idata[dataIdx];
version2:
//__constant__ int* c_idata;
//__constant__ int* c_odata;
void
int* c_idata;
int* c_odata;
...//below all the same
Thanks, I’m afraid I can’t quite follow you by “symbol overload” and “signature”. Could you please as well point to some examples on how to use ConstantMemory? Thanks!
