Constant memory when having more than one file external does not work
[codebox]
///// simpleClass.cu//////////////
class simpleClass {
public:
 int *array;
device simpleClass *test;
/////////Kernel.cu /////////////
#include “simpleClass.cu”
host_function()
 simpleClass *temp;
 int  *temp_array;
cudaMalloc(&temp,(size_t)(sizeof(simpleClass)*100));
 cudaMemcpyToSymbol(test,&temp,sizeof(simpleClass*),0,cudaMemcpyHostToDevice);
cudaMalloc(&temp_array, (size_t)(sizeof(int)*100));
 cudaMemcpy(&(temp->array), &temp_array, sizeof(temp->array), cudaMemcpyHostToDevice);
[/codebox]
or, for a statically allocated class
[codebox]
device simpleClass stat;
host_function()
 int  *temp_array;
 cudaMemcpyToSymbol(stat, &temp_array, sizeof(stat.array), offsetof(simpleClass, array), cudaMemcpyHostToDevice);
[/codebox]
Thanks for the reply but i already tried what you suggested in the first code box . The cudamemcpy gives an runtime api error : invalid argument error…
I tried to get it done using cudaMemcpyToSymbol , but couldn’t. Nevertheless, here’s a way to do it without cudaMemcpyToSymbol.
[codebox]include <stdio.h>
include <stdlib.h>
include <cutil_inline.h>
class simpleClass {
public:
int *array;
global void wtf(int classes, int intsperclass,simpleClass *test)
int cla=blockIdx.x, intn=threadIdx.x;
if (cla>=classes || intn>=intsperclass) return;
test[cla].array[intn]=cla*classes+intn;
int main(void)
simpleClass *d_sc,*h_sc;
cudaMalloc(&d_sc,sizeof(simpleClass)*100);
h_sc=(simpleClass *)malloc(sizeof(simpleClass)*100);
for (int i=0;i<100;i++)
	cudaMalloc(&h_sc[i].array,(size_t)(sizeof(int)*100));
cudaMemcpy(d_sc,h_sc,sizeof(simpleClass)*100,cudaMemcpyHostT
oDevice);
wtf<<<100,100>>>(100,100,d_sc);
cutilCheckMsg( "Kernel execution failed" );
cudaThreadSynchronize();
// test just a single array
int *check=(int*)malloc(sizeof(int)*100);
cudaMemcpy(check,h_sc[34].array,100*sizeof(int),cudaMemcpyDe
viceToHost);
for (int i=0;i<100;i++) printf("%d: %d\n",i,check[i]);
	cudaFree(h_sc[i].array);
cudaFree(d_sc);
free(h_sc);
free(check);
return 0;
[/codebox]
It requires having a hostcopy of the classarray with the pointers. I hope that is acceptable.
include <stdlib.h>
class simpleClass {
public:
int *array;
int main(void)
oDevice);
viceToHost);
cudaFree(d_sc);
free(h_sc);
free(check);
return 0;
[/codebox]
