Hi pros,
I want to copy a big 512 cubic volume to constant memory.
Is there any declaration like:
constant float* volume;
possible? From the programming guide I know that volume has to be of a certain size which I have to set before. But my volume is to big to fit into the constant memory. So I thought about
declaring it with a pointer and the values are copied to the constant memory when needed.
Without success. It says: invalid argument.
Is the texture memory (which is cached, too) the only alternative solution to my problem?
Thank you,
bye moe4life
