HI,
I was trying to initialize constant memory in module like this:
module abc
integer, constant :: dd = 100
end module abc
but it seems that the value of dd is 0.
What’s happening?
HI,
module abc
end module abc
What’s happening?
Hi qijiin21c,
You need to set the constant in executable code.
Hope this helps,
Mat
Hi, Mat,
But what is a executable code? Is it convenient?
Thanks a lot?
By “executable” code, I mean code that’s executed in the program instead of statically initialized.
module abc
end module abc
program foo
use abc
dd = 100
end program foo
Hope that clarifies things,
Mat
