Constant Xorg freezes (EQ overflows)
Hi. I have been getting a lot of xorg freezes which renders my system unusable except for my mouse, and I have to do a hard power off to kill it. Normally it seemed to happen most often with firefox or mplayer with vdpau, but just recently happened within a terminal.
My system is:
-ZOTAC GTS 450 AMP Edition (Nvidia driver 331.20)
-Xorg server 1.14
-Slackware 14.1 (3.10 kernel)
-XFCE desktop (no compositing)
Here is the common EQ overflow output I get from Xorg.0.log.old after a system reboot:
(EE) [mi] EQ overflowing.  Additional events will be discarded until existing events are processed.
(EE)
(EE) Backtrace:
(EE) 0: /usr/bin/X (xorg_backtrace+0x49) [0x81d6099]
(EE) 1: /usr/bin/X (mieqEnqueue+0x21b) [0x81b616b]
(EE) 2: /usr/bin/X (QueuePointerEvents+0x6d) [0x80911cd]
(EE) 3: /usr/bin/X (xf86PostMotionEventM+0x24b) [0x80ca34b]
(EE) 4: /usr/lib/xorg/modules/input/evdev_drv.so (0xb3855000+0x4b7f) [0xb3859b7f]
(EE) 5: /usr/bin/X (0x8048000+0x71cb5) [0x80b9cb5]
(EE) 6: /usr/bin/X (0x8048000+0x9c4a7) [0x80e44a7]
(EE) 7: linux-gate.so.1 (__kernel_sigreturn+0x0) [0xffffe400]
(EE) 8: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0xb4348000+0x359c5) [0xb437d9c5]
(EE)
(EE) [mi] These backtraces from mieqEnqueue may point to a culprit higher up the stack.
(EE) [mi] mieq is *NOT* the cause.  It is a victim.
(EE) [mi] EQ overflow continuing.  100 events have been dropped.
(EE)
(EE) Backtrace:
(EE) 1: /usr/bin/X (mieqEnqueue+0xe8) [0x81b6038]
(EE)
(EE) [mi] EQ overflow continuing.  200 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing.  300 events have been dropped.
(EE)
(EE) Backtrace:
(EE)
(EE) [mi] EQ overflow continuing.  400 events have been dropped.
(EE)
(EE) Backtrace:
(EE) 3: /usr/bin/X (xf86PostButtonEventM+0x93) [0x80ca7c3]
(EE) 4: /usr/bin/X (xf86PostButtonEvent+0xab) [0x80ca87b]
(EE) 5: /usr/lib/xorg/modules/input/evdev_drv.so (0xb3855000+0x48a1) [0xb38598a1]
(EE) 6: /usr/bin/X (0x8048000+0x71cb5) [0x80b9cb5]
(EE) 7: /usr/bin/X (0x8048000+0x9c4a7) [0x80e44a7]
(EE) 8: linux-gate.so.1 (__kernel_sigreturn+0x0) [0xffffe400]
(EE) 9: /usr/lib/xorg/modules/drivers/nvidia_drv.so (0xb4348000+0x359c5) [0xb437d9c5]
(EE)
(EE) [mi] EQ overflow continuing.  500 events have been dropped.
Where is the attachment option so I can include a bug report log?
nvidia-bug-report.log.gz (76.1 KB)
I found the attachment option, my post wouldn’t edit that last line out though.
See advice.
So I should try patching the xorg server to raise the mieq size?
EDIT: I haven’t had issues like this ever on previous versions of Slackware and then I get them all the time now. It seems odd that it wouldn’t be a driver related issue, unless something dramatically changed with xorg or the kernel.
EDIT 2: Also the xorg freeze/lockup used to predictably happen during initial launch of firefox, though it would be open fine ~19/20 times. I have since disabled hardware acceleration in firefox and I don’t think it’s happened again with firefox but it may just be luck, don’t know. Now that the EQ overflow xorg freeze happened from just a terminal, I’m a lot more concerned and it appears to be a larger problem than I anticipated.
