Running server on port 8009
Client connected from ::ffff:[my ip]
Initializing Jarvis ASR
Error via streamingRecognize callback
Error: 14 UNAVAILABLE: failed to connect to all addresses
at Object.exports.createStatusError (/workspace/samples/jarvis-contact/node_modules/grpc/src/common.js:91:15)
at ClientDuplexStream._emitStatusIfDone (/workspace/samples/jarvis-contact/node_modules/grpc/src/client.js:233:26)
at ClientDuplexStream._receiveStatus (/workspace/samples/jarvis-contact/node_modules/grpc/src/client.js:211:8)
at Object.onReceiveStatus (/workspace/samples/jarvis-contact/node_modules/grpc/src/client_interceptors.js:1311:15)
at InterceptingListener._callNext (/workspace/samples/jarvis-contact/node_modules/grpc/src/client_interceptors.js:568:42)
at InterceptingListener.onReceiveStatus (/workspace/samples/jarvis-contact/node_modules/grpc/src/client_interceptors.js:618:8)
at /workspace/samples/jarvis-contact/node_modules/grpc/src/client_interceptors.js:1127:18 {
code: 14,
metadata: Metadata { _internal_repr: {}, flags: 0 },
details: ‘failed to connect to all addresses’
Unfortunately no. No one from NVIDIA ever got back to me after I posted the logs and I was unable to figure it out on my own. It’s too bad, because it’s a very interesting use case that I would have liked to seen live.
Hi @brian.b
Just wanted to confirm, does the security group has port forward enabled for ports 8009 and 9000?
Also, does config file env.txt has updated value set for URL of your running Riva AI Services?
Thanks for your reply. I confirm that in my case, the issue is resolved by changing IP address in env.txt file.
# Configuration environment vars for Riva Contact
# Replace the IP and port with your hosted RIVA endpoint
#RIVA_API_URL="0.0.0.0:50051"
RIVA_API_URL="YOUR_SERVER_IP_HERE:50051" # <------ CHANGE HERE!!!
# NER model to use. This one is the default from the Riva Quick Start setup
RIVA_NER_MODEL="riva_ner"
# NER entities to use from the above model (can be a subset of what is offered)
RIVA_NER_ENTITIES="per,loc,org,time,misc"
# The port your Node.js app will be hosted at
PORT="8009"
# Port for the peer-js server, to be used for negotiating the peer-to-peer chat connection
PEERJS_PORT="9000"
