A fortran code having contained subroutine inside main program does not seem not to work for me.
In the pasted below an example
when main code has the contained subroutine “l_print__” i,
the second call of
call index_all_woverlap(‘b2’, iv)
it return the size of array iv be 4 instead of 2
I tried with pgi version 18.7 to 19.9 ; all behave the same: had the wrong size of
iv2 after the 2nd call of index_all_woverlap
Deleting / commenting the contained subroutine “l_print__”
the code works OK.
Is this a bug or I am still missing some f90/08 rule somehow ?
ifort and gfortran worked OK.
sample code (simplified to underline the issue)
module a_m
public :: index_all_woverlap
public :: iv2str
contains
subroutine index_all_woverlap( s_in, i_loc )
implicit none
integer, intent(out),allocatable :: i_loc(:)
character(*), intent(in) :: s_in
if(len(s_in)<1) then
allocate(i_loc(0))
return
endif
allocate(i_loc(len(s_in)))
print*,'size(i_loc)=',size(i_loc)
end subroutine index_all_woverlap
function iv2str(iv) result ( u )
implicit none
integer, intent(in) :: iv(:)
integer i
character(:),allocatable :: u
u=' ' ! same if return u=''
end function iv2str
end module a_m
program main
use a_m
implicit none
integer, allocatable :: iv(:), iv1(:)
call index_all_woverlap( ' +4 ', iv)
print*,'A>>',size(iv),'"',iv,'"' ! returns 4 (OK)
call index_all_woverlap('b2', iv)
print*,'B>>',size(iv),'"',iv,'"' ! not ok; returns 4 (but should be 2)
stop
print*,'siuze iv',size(iv)
print*,'iv="'//iv2str(iv)//'"'
contains
subroutine l_print__ !lset_keys_(str_)
! character(), intent(in) :: str_
print,’??’
end subroutine l_print__ !lset_keys_
end program main
