I am installing Graph Composer 1.0 on Jetson 6.0.1
I downloaded the graph composer 1.0 from Nvidias website 3 files downloaded then I run this command to install
sudo dpkg -i graph_composer-1.0.0_arm64.deb
then
I ran the commands registry --help and container_builder --help to verify if Graph composer is installed correctly but after running container_builder --help it shows that container_builder command not found
and
container_builder` executable binary is not there in the folder of opt/nvidia/graph-consumer.
how to install container_builder executable file please provide the complete Guidance
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
