Working on building a container using the container builder button in the graph composer. I’m working remotely on a A4000 RTX GPU, connected to my windows device using the IP address and port to get connected. Attached are the steps I take to build the container, the config file code, and the error message. Please let me know what there is that I could do to make it work.
To add on, I think this may be because of the rsync version, I have tried to download that required by composer but it doesn’t seem to exist
I have to admit I have never heard of this before. You are looking to just build a container for Composer? What exactly are you trying to achieve so I can best help you?
I am just trying to build the container from composer, I was following this documentation:
Building the 3 node graph, it runs but I cannot build the container
Ok. No, I have never heard of this before. This is not part of Omniverse. This looks like a developer workflow. I think I should move this post to the Developer area.
Please do, thank you
Important to note that the remote machine is a Ubuntu 22.04 machine
• DeepStream Version
• TensorRT Version
Why did the windows directory appear? Are you working on windows or ubuntu?
Have you installed DeepStream SDK? Have you downloaded all public extensions from NGC before you build the container?
