Container Communication in Drive Orin
Software Version
DRIVE OS 6.0.8.1
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.3.10904
other
Host Machine Version
other
My System 1 is Drive Orin and in that i have created two containers and my System 2 is Jetson Orin, I have created the containers in Drive Orin (System 1) using the net=host option, so that the containers are exposed to the host ethernet port. While I am running a single container, then I am achieving desired performance, but when I am trying to run both the containers at the same instance, then both the containers are not receiving proper data, so requesting help in this regard.
Dear @arpit.agarkar,
Do you notice packet loss on that interface? Could you share repro steps?
Basically I am using vsomeIP Siva, and yes, data loss was happening, both the containers were not receiving proper data
Can this use case tested using iperf?
sorry, but I am not sure about the same.
As per this thread, Can two docker both set host network mode? - Stack Overflow , its not possible for the 2 containers with net=host to receive data from ethernet simulatenously
Thank you for sharing the info.
