Description
i ran my application in docker with sudo docker run --runtim nvidia … ,but it get segment fault at context_->setDeviceMemory . here is my code:
bool TensorRT::InitFromEngine(std::string &model_data) {
runtime_ = nvinfer1::createInferRuntime(*ilogger_ptr_);
engine_ = runtime_->deserializeCudaEngine(model_data.data(),
model_data.size(), nullptr);
// context_ = engine_->createExecutionContext();
context_ = engine_->createExecutionContextWithoutDeviceMemory();
ASSERT_TRUE_AND_RETURN(engine_ != nullptr);
return true;
bool TensorRT::InitFromModel(std::string &model_data, const BuildConfig &build_config) {
nvinfer1::IBuilder *builder = nvinfer1::createInferBuilder(*ilogger_ptr_);
const auto explicit_batch = 1U << static_cast<uint32_t>(
nvinfer1::NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
nvinfer1::INetworkDefinition *network =
builder->createNetworkV2(explicit_batch);
nvonnxparser::IParser *parser = nvonnxparser::createParser(*network, *ilogger_ptr_);
parser->parse(model_data.data(), model_data.size());
for (int i = 0; i < parser->getNbErrors(); ++i) {
ilogger_ptr_->log(nvinfer1::ILogger::Severity::kERROR,
parser->getError(i)->desc());
SetExtraNetworkOptions(network, build_config._input_infos,
build_config._output_infos);
builder->setMaxBatchSize(build_config._max_batchsize);
nvinfer1::IBuilderConfig *config = builder->createBuilderConfig();
config->setMaxWorkspaceSize(1 << 20);
SetExtraConfigOptions(config, builder, build_config._builder_flags,
build_config._profile_infos);
engine_ = builder->buildEngineWithConfig(*network, *config);
config->destroy();
network->destroy();
builder->destroy();
ASSERT_TRUE_AND_RETURN(context_ != nullptr);
return true;
int TensorRT::Run(std::vector<void *> &devices,
const std::vector<std::vector<size_t>> &input_shapes,
const int batch_size) {
for (size_t i = 0; i < input_shapes.size(); ++i) {
nvinfer1::Dims dim;
VectorToNvDims(input_shapes[i], dim);
context_->setBindingDimensions(static_cast<int>(i), dim);
cudaMalloc(&data, engine_->getDeviceMemorySize());
context_->setDeviceMemory(data);
bool status = context_->executeV2(devices.data());
if (!status) {
throw std::runtime_error("failed to execute tensorrt");
return 0;
Environment
TensorRT Version: 7.2.2
GPU Type: tesla v100
Nvidia Driver Version: 495
CUDA Version: 11.1
CUDNN Version: 8
Operating System + Version: ubuntu18.04
base Docker image: nvidia/cuda:11.1.1-cudnn8-devel-ubuntu18.04
question
can anyone help me to solve this problem? if my code is correct, did i miss some config?
