I a have Jetson-Xavier with jetpack 4.6 and a docker image with jetpack 4.6.1 as base image. I have removed all the files in “/etc/nvidia-container-runtime/host-files-for-container.d/” as I want to have everything in my image. Everything works perfectly but when I make a gstreamer.csv in “/etc/nvidia-container-runtime/host-files-for-container.d/” the conatiner does not build and gives the following error:
WARNING: Published ports are discarded when using host network mode
docker: Error response from daemon: OCI runtime create failed: container_linux.go:380: starting container process caused: process_linux.go:545: container init caused: Running hook #0:: error running hook: signal: segmentation fault (core dumped), stdout: , stderr: exec command: [/usr/bin/nvidia-container-cli --load-kmods configure --ldconfig=@/sbin/ldconfig.real --device=all --compute --compat32 --graphics --utility --video --display --pid=22905 /data/docker_data/overlay/298d024a601dd1f292a4cff8377f528e10144087dc94f13ea6b47873a9882704/merged]: unknown.
ERRO[0000] error waiting for container: context canceled
I use the following command for running the container in both times (with and without gstreamer.csv):
docker run -it --name=docker_test --net=host --runtime nvidia -e CUDA_VER=10.2 -w /mnt/SSD/WORK/ -p 23000:23000/udp -p 22:22/udp --privileged docker_jp461_ds51:1.0
and the gstreamer.csv looks like this:
sym, /usr/lib/aarch64-linux-gnu/libclutter-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libclutter-1.0.so.0.2600.2
sym, /usr/lib/aarch64-linux-gnu/libgraphene-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgraphene-1.0.so.0.800.0
sym, /usr/lib/aarch64-linux-gnu/libgomp.so.1
lib, /usr/lib/aarch64-linux-gnu/libgomp.so.1.0.0
dir, /usr/lib/aarch64-linux-gnu/gstreamer-1.0
sym, /usr/lib/aarch64-linux-gnu/libgstadaptivedemux-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstadaptivedemux-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstallocators-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstallocators-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstallocators-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstapp-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstapp-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstapp-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstaudio-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstaudio-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstaudio-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstbadaudio-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstbadaudio-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstbadvideo-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstbadvideo-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstbase-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstbasecamerabinsrc-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstbasecamerabinsrc-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstcheck-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstcheck-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstcheck-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstcodecparsers-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstcodecparsers-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstcontroller-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstcontroller-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstcontroller-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstfft-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstfft-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstfft-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstgl-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstgl-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstgl-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstinsertbin-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstinsertbin-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstisoff-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstisoff-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstmpegts-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstmpegts-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstnet-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstnet-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstnet-1.0.so.0.1405.0
lib, /usr/lib/aarch64-linux-gnu/libgstnvegl-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstnvexifmeta.so
lib, /usr/lib/aarch64-linux-gnu/libgstnvivameta.so
sym, /usr/lib/aarch64-linux-gnu/libgstpbutils-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstpbutils-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstpbutils-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstphotography-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstphotography-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstplayer-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstplayer-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstreamer-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstriff-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstriff-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstriff-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstrtp-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstrtp-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstrtp-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstrtsp-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstrtsp-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstrtsp-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstrtspserver-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstrtspserver-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstsdp-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstsdp-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstsdp-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgsttag-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgsttag-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgsttag-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgsturidownloader-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgsturidownloader-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so
sym, /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstvideo-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstwayland-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstwayland-1.0.so.0.1405.0
sym, /usr/lib/aarch64-linux-gnu/libgstwebrtc-1.0.so.0
lib, /usr/lib/aarch64-linux-gnu/libgstwebrtc-1.0.so.0.1405.0
The strange thing is that everything works perfectly on another Xavier with jetpack 4.6.2 !
p.s. the idea here is to keep the host system as clean as possible and have everything inside the container.
Any idea what could the problem be ?
