Continual OpenGL Driver Cannot Be Found Error
The issue is occuring on a
Asus Strix GL553VE Laptop
i7-7700HQ 2.8GHz
RAM: 16 GB
Video: GeForce GTX 1050 Ti
Newest Driver Installed
In working in Premiere Pro CC 2018 and also version 2017, Premiere hangs as soon as I import any footage type (pic or video) into a project. This is the log from the Event Viewer:
TLog Name: Application
Source: NVIDIA OpenGL Driver
Date: 3/16/2018 10:57:23 AM
Event ID: 1
Task Category: None
Level: Error
Keywords: Classic
Description:
The description for Event ID 1 from source NVIDIA OpenGL Driver cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
Unable to communicate with the display driver. The application must close.
Error code: 2
(pid=13368 tid=12672 adobe premiere pro.exe 64bit)
Visit http://www.nvidia.com/page/support.html for more information.
the message resource is present but the message is not found in the string/message table
Additional Info:
Faulting application name: Adobe Premiere Pro.exe, version: 12.0.1.69, time stamp: 0x5a4defd6
Faulting module name: nvoglv64.dll, version: 23.21.13.9101, time stamp: 0x5a9067f0
Exception code: 0xc0000409
Fault offset: 0x0000000000fdeda9
Faulting process id: 0x3438
Faulting application start time: 0x01d3bd36551b6bb3
Faulting application path: C:\Program Files\Adobe\Adobe Premiere Pro CC 2018\Adobe Premiere Pro.exe
Faulting module path: C:\WINDOWS\System32\DriverStore\FileRepository\nvami.inf_amd64_40f9e134b62f4f99\nvoglv64.dll
Report Id: cecbe576-5c1a-4d0f-9c0c-c63111b1f27e
Faulting package full name:
Faulting package-relative application ID:
Update:
I uninstalled the Intel Graphics Driver and let Windows install the system default and Adobe works.
For anyone else facing this issue it’s the driver from Intel as I had downloaded those drivers as well. Go figure.
