"continue" in kernel program
I’m writing a kernel to calculate sparse gemm, so there will be some padding. To reduce redundent calculation, I use flag to indicate if I need mma for a tile. However, after I add flag, though I find that I use 30% less HMMA instructions (means I’ve suceessfully reduce 30% of calculation), but the kernel cost 20% more time then before.
my code clip like below
__global__ void f() {
  __shared__ flag[32];
  bool reg_flag[4];
  for (i =0; i < 32; i++) {
    // calculate reg_flagp[0-3] by flag[i] and i and warp_id
    // load matrix B0, B1, B2, B3
    for (int j = 0; j < 4; j++) {
      if (!reg_flag[j]) {continue;}
      // load matrix Ai
      // mma for Ai * B0, B1, B2, B3
I have no idea why this strange thing happens. I don’t think it will cause warp divergence as reg_flag are same in a warp.
Also, when I add the flag line, I find that nvcc use less registers. I don’t known why.
Check the generated machine code (SASS).
The added if-statement likely interferes with loop unrolling. My expectation is that the loops in the original code without the if-statement get fully unrolled. Once control flow is “linearized”, all loads are moved to the top as far as possible to increase latency tolerance, requiring additional registers for temporary storage. This results in the best performance.
Was reg_flag moved into local memory?
Try to #pragma unroll both loops.
No, there is 0 byte use of local memory. I used #pragma but have no result.
But I used unroll and I find that in PTX, the loop was truly unroll. They have the same num of “mma.sync.aligned.m16n8k16.row.col.f32.f16.f16.f32”
Probably it uses preloading less aggressively. Is A_i or something else in global memory?
No,Ai, Bi are already loaded in shared memory and wait to be loaded into register
I look at the sass and find that for no flag version, 16 HMMA instructions are grouped. But for flag verison, 4 HMMA are grouped. They all have 16 instructions in all.
here is a clip of flaged version
        /*19b0*/              @!P0 BRA `(.L_x_11) ;
        /*19c0*/                   LDS R84, [R97.X4+0x7180] ;
        /*19d0*/                   WARPSYNC 0xffffffff ;
        /*19e0*/                   ISETP.NE.AND P0, PT, R89, RZ, PT ;
        /*19f0*/                   LEA.HI R85, R84, R84, RZ, 0x1 ;
        /*1a00*/                   SHF.R.S32.HI R86, RZ, 0x1, R85.reuse ;
        /*1a10*/                   SHF.R.S32.HI R87, RZ, 0x1f, R85 ;
        /*1a20*/                   LOP3.LUT R85, R85, 0xffffffe, RZ, 0xc0, !PT ;
        /*1a30*/                   LEA.HI R87, R87, R86, RZ, 0x2 ;
        /*1a40*/                   IMAD.IADD R85, R84, 0x1, -R85 ;
        /*1a50*/                   LOP3.LUT R87, R87, 0x3ffffffc, RZ, 0xc0, !PT ;
        /*1a60*/                   IMAD.SHL.U32 R85, R85, 0x10, RZ ;
        /*1a70*/                   IMAD.IADD R87, R86.reuse, 0x1, -R87 ;
        /*1a80*/                   IMAD.SHL.U32 R86, R86, 0x20, RZ ;
        /*1a90*/                   LOP3.LUT R87, R87, R98, RZ, 0x3c, !PT ;
        /*1aa0*/                   IMAD.SHL.U32 R87, R87, 0x4, RZ ;
        /*1ab0*/                   IADD3 R84, R87, R86, R85 ;
        /*1ac0*/                   LEA R84, R84, c[0x0][0x18], 0x2 ;
        /*1ad0*/                   IADD3 R84, R84, -c[0x0][0x18], RZ ;
        /*1ae0*/                   LDSM.16.M88.4 R84, [R84] ;
        /*1af0*/                   HMMA.16816.F32 R44, R84.reuse, R80, R44 ;
        /*1b00*/                   HMMA.16816.F32 R48, R84.reuse, R82, R48 ;
        /*1b10*/                   HMMA.16816.F32 R52, R84.reuse, R76, R52 ;
        /*1b20*/                   HMMA.16816.F32 R56, R84, R78, R56 ;
and this is no flag version, all HMMA are consecutive
        /*1420*/                   BAR.SYNC 0x0 ;
        /*1430*/                   LDS R78, [R106.X4+0x7100] ;
        /*1440*/                   IADD3 R115, R115, 0x1, RZ ;
        /*1450*/                   LDS R83, [R106.X4+0x7140] ;
        /*1460*/                   ISETP.NE.AND P1, PT, R115, 0x1b, PT ;
        /*1470*/                   LDS R77, [R106.X4+0x7180] ;
        /*1480*/                   LDS R76, [R106.X4+0x71c0] ;
        /*1490*/                   LEA.HI R79, R78, R78, RZ, 0x1 ;
        /*14a0*/                   SHF.R.S32.HI R80, RZ, 0x1, R79.reuse ;
        /*14b0*/                   SHF.R.S32.HI R81, RZ, 0x1f, R79 ;
        /*14c0*/                   LEA.HI R84, R83, R83, RZ, 0x1 ;
        /*14d0*/                   LEA.HI R81, R81, R80, RZ, 0x2 ;
        /*14e0*/                   LOP3.LUT R79, R79, 0xffffffe, RZ, 0xc0, !PT ;
        /*14f0*/                   LOP3.LUT R81, R81, 0x3ffffffc, RZ, 0xc0, !PT ;
        /*1500*/                   SHF.R.S32.HI R86, RZ, 0x1f, R84.reuse ;
        /*1510*/                   IMAD.IADD R79, R78, 0x1, -R79 ;
        /*1520*/                   LEA.HI R85, R76, R76, RZ, 0x1 ;
        /*1530*/                   IMAD.IADD R82, R80.reuse, 0x1, -R81 ;
        /*1540*/                   SHF.R.S32.HI R81, RZ, 0x1, R84 ;
        /*1550*/                   IMAD.SHL.U32 R78, R80, 0x20, RZ ;
        /*1560*/                   LOP3.LUT R84, R84, 0xffffffe, RZ, 0xc0, !PT ;
        /*1570*/                   IMAD.SHL.U32 R79, R79, 0x10, RZ ;
        /*1580*/                   LOP3.LUT R82, R82, R107, RZ, 0x3c, !PT ;
        /*1590*/                   LEA.HI R86, R86, R81, RZ, 0x2 ;
        /*15a0*/                   IMAD.IADD R84, R83, 0x1, -R84 ;
        /*15b0*/                   SHF.R.S32.HI R87, RZ, 0x1, R85.reuse ;
        /*15c0*/                   IMAD.SHL.U32 R82, R82, 0x4, RZ ;
        /*15d0*/                   LOP3.LUT R86, R86, 0x3ffffffc, RZ, 0xc0, !PT ;
        /*15e0*/                   IMAD.SHL.U32 R84, R84, 0x10, RZ ;
        /*15f0*/                   SHF.R.S32.HI R88, RZ, 0x1f, R85 ;
        /*1600*/                   IADD3 R78, R82, R78, R79 ;
        /*1610*/                   IMAD.IADD R86, R81, 0x1, -R86 ;
        /*1620*/                   LEA.HI R79, R77, R77, RZ, 0x1 ;
        /*1630*/                   IMAD.SHL.U32 R81, R81, 0x20, RZ ;
        /*1640*/                   LEA.HI R88, R88, R87, RZ, 0x2 ;
        /*1650*/                   SHF.R.S32.HI R80, RZ, 0x1, R79.reuse ;
        /*1660*/                   SHF.R.S32.HI R83, RZ, 0x1f, R79 ;
        /*1670*/                   LOP3.LUT R86, R86, R107, RZ, 0x3c, !PT ;
        /*1680*/                   LEA.HI R83, R83, R80, RZ, 0x2 ;
        /*1690*/                   LOP3.LUT R88, R88, 0x3ffffffc, RZ, 0xc0, !PT ;
        /*16a0*/                   IMAD.SHL.U32 R86, R86, 0x4, RZ ;
        /*16b0*/                   LOP3.LUT R83, R83, 0x3ffffffc, RZ, 0xc0, !PT ;
        /*16c0*/                   LOP3.LUT R82, R79, 0xffffffe, RZ, 0xc0, !PT ;
        /*16d0*/                   IMAD.IADD R88, R87, 0x1, -R88 ;
        /*16e0*/                   IADD3 R81, R86, R81, R84 ;
        /*16f0*/                   IMAD.IADD R84, R80, 0x1, -R83 ;
        /*1700*/                   LOP3.LUT R85, R85, 0xffffffe, RZ, 0xc0, !PT ;
        /*1710*/                   IMAD.IADD R82, R77, 0x1, -R82 ;
        /*1720*/                   LOP3.LUT R88, R88, R107.reuse, RZ, 0x3c, !PT ;
        /*1730*/                   IMAD.SHL.U32 R80, R80, 0x20, RZ ;
        /*1740*/                   LOP3.LUT R84, R84, R107, RZ, 0x3c, !PT ;
        /*1750*/                   IMAD.IADD R85, R76, 0x1, -R85 ;
        /*1760*/                   LEA R78, R78, c[0x0][0x18], 0x2 ;
        /*1770*/                   IMAD.SHL.U32 R87, R87, 0x20, RZ ;
        /*1780*/                   LEA R89, R81, c[0x0][0x18], 0x2 ;
        /*1790*/                   IMAD.SHL.U32 R77, R82, 0x10, RZ ;
        /*17a0*/                   IADD3 R81, R78, -c[0x0][0x18], RZ ;
        /*17b0*/                   IMAD.SHL.U32 R84, R84, 0x4, RZ ;
        /*17c0*/                   IADD3 R89, R89, -c[0x0][0x18], RZ ;
        /*17d0*/                   IMAD.SHL.U32 R76, R85, 0x10, RZ ;
        /*17e0*/                   IMAD.SHL.U32 R88, R88, 0x4, RZ ;
        /*17f0*/                   IADD3 R80, R84, R80, R77 ;
        /*1800*/                   IADD3 R88, R88, R87, R76 ;
        /*1810*/                   LEA R92, R80, c[0x0][0x18], 0x2 ;
        /*1820*/                   LDSM.16.M88.4 R76, [R100] ;
        /*1830*/                   LEA R96, R88, c[0x0][0x18], 0x2 ;
        /*1840*/                   IADD3 R92, R92, -c[0x0][0x18], RZ ;
        /*1850*/                   LDSM.16.M88.4 R80, [R81] ;
        /*1860*/                   IADD3 R96, R96, -c[0x0][0x18], RZ ;
        /*1870*/                   LDSM.16.M88.4 R84, [R101] ;
        /*1880*/                   LDSM.16.M88.4 R88, [R89] ;
        /*1890*/                   LDSM.16.M88.4 R92, [R92] ;
        /*18a0*/                   LDSM.16.M88.4 R96, [R96] ;
        /*18b0*/                   HMMA.16816.F32 R12, R80.reuse, R76, R12 ;
        /*18c0*/                   HMMA.16816.F32 R16, R80.reuse, R78, R16 ;
        /*18d0*/                   HMMA.16816.F32 R20, R80.reuse, R84, R20 ;
        /*18e0*/                   HMMA.16816.F32 R24, R80, R86, R24 ;
        /*18f0*/                   HMMA.16816.F32 R28, R88.reuse, R76, R28 ;
        /*1900*/                   HMMA.16816.F32 R32, R88.reuse, R78, R32 ;
        /*1910*/                   HMMA.16816.F32 R36, R88.reuse, R84, R36 ;
        /*1920*/                   HMMA.16816.F32 R40, R88, R86, R40 ;
        /*1930*/                   HMMA.16816.F32 R44, R92.reuse, R76, R44 ;
        /*1940*/                   HMMA.16816.F32 R48, R92.reuse, R78, R48 ;
        /*1950*/                   HMMA.16816.F32 R52, R92.reuse, R84, R52 ;
        /*1960*/                   HMMA.16816.F32 R56, R92, R86, R56 ;
        /*1970*/                   HMMA.16816.F32 R60, R96.reuse, R76, R60 ;
        /*1980*/                   HMMA.16816.F32 R64, R96.reuse, R78, R64 ;
        /*1990*/                   HMMA.16816.F32 R68, R96.reuse, R84, R68 ;
        /*19a0*/                   HMMA.16816.F32 R72, R96, R86, R72 ;
        /*19b0*/                   BAR.SYNC 0x0 ;
Looking at PTX will not tell us anything sufficiently material. PTX is translated into SASS by ptxas, which is an optimizing compiler, with loop unrolling included as one of the optimizations. When analyzing code performance, only an inspection of the generated SASS can generate actionable information.
A meaningful analysis would be based on the side-by-side comparison of the SASS generated for the two variants of the entire kernel. At this point, only you are enabled to perform this analysis.
I think it is truly the problem of unroll. As for no flag version, it can unroll to 16. But for flag version, it can only unroll to 4.
Actually, in my code
int tmp_flag = flag[ker_idx];
for (int i = 0; i < 4; i++) {
    reg_flag[i] = tmp_flag & (1 << ((warp_id % 2) * 4 + i));
__syncwarp();
this is how I calc flag. It is said, for a ker_idx, the warp has 16 different conditions of flag.
So How can I just enhanced the unroll progression? Do I need to use switch to eliminated the use of continue?
will this convertion be better?
if (flag[ker_idx] == 2b'1111) {...}
else if (flag[ker_idx] == 2b'1110) {...}
else if (flag[ker_idx] == 2b'0001) {...}
else {...}
I unroll the continue manully. Is there any way to use something like templete to write the code more elegently?
Why not switch…case?
Also consider changing reg_flag from a bool array to an int, where each bit is a flag.
Bits can be accessed by index, registers / register arrays not (except with local memory).
So you mean, I need to use switch to write the same code clip for 16 times? Is there any better and simplier way to solve this?
I don’t get the idea of this sentence.
If you put reg_flag[4] into a single int, you can just load its value by index. From shared memory or from constant memory (if usually constant between lanes).
With arithmetic instructions or intrinsics you can read or set or reset a specific bit. The bit can be specified as a dynamic (runtime) value.
A local array has to have all its indices known at compile-time to be stored in registers.
I get it. I move flag to register just to accelarate the speed. But it has very little use.
So what about this? how can I get rid of continue and have a better unroll preformance
