I have been pulling my hair out just trying to get X to work properly on my machine. I had it working for a while but something changed and now I am at the point of nearly giving up on setting up the configuration.
I have 2 machines, one which I magically was able to get working with the same display and the other which doesn’t work (on boot, i get no X and my display turns off). If i ctrl-alt-2 to get to another terminal i just get the blinking cursor (SSH works fine).
I have tried all the different options I have found online, but nothing seems to work (nomodeset, using xorg.conf.d instead of the default xorg.conf file, stripping out all but one GPU and regenerating nvidia-xconfig, xrandr --auto in ~/.xinitrc, switching to lightdm, force reinstalling gdm3, force reinstalling nvidia-driver-460, blacklisting nouveau).
systemctl status gdm3 shows it’s fine:
● gdm.service - GNOME Display Manager
Loaded: loaded (/lib/systemd/system/gdm.service; static; vendor preset: enabled)
Active: active (running) since Fri 2021-06-25 22:27:41 BST; 9min ago
Process: 1655 ExecStartPre=/usr/share/gdm/generate-config (code=exited, status=0/SUCCESS)
Process: 1671 ExecStartPre=/usr/lib/gdm3/gdm-wait-for-drm (code=exited, status=0/SUCCESS)
Main PID: 1672 (gdm3)
Tasks: 3 (limit: 231646)
Memory: 9.1M
CGroup: /system.slice/gdm.service
└─1672 /usr/sbin/gdm3
the only thing I noticed different between when i plug into one machine vs the other seems to be autdetection of the display, where i am able to find this on the working machine:
/usr/lib/gdm3/gdm-x-session[2813]: (==) NVIDIA(0): No modes were requested; the default m>
/usr/lib/gdm3/gdm-x-session[2813]: (==) NVIDIA(0): will be used as the requested mode.
/usr/lib/gdm3/gdm-x-session[2813]: (II) NVIDIA(0): Validated MetaModes:
/usr/lib/gdm3/gdm-x-session[2813]: (II) NVIDIA(0): “DFP-7:nvidia-auto-select”
/usr/lib/gdm3/gdm-x-session[2813]: (II) NVIDIA(0): Virtual screen size determined to be 3>
/usr/lib/gdm3/gdm-x-session[2813]: (–) NVIDIA(0): DPI set to (325, 211); computed from ">
/usr/lib/gdm3/gdm-x-session[2813]: (–) NVIDIA(0): option
Where on the non-working machine all i get is:
/usr/lib/gdm3/gdm-x-session[1824]: (II) NVIDIA(0): Validated MetaModes:
/usr/lib/gdm3/gdm-x-session[1824]: (II) NVIDIA(0): “NULL”
On the working machine, i had a hard time getting it up and running as well, but ultimately fixed by having the “Device” section for the device with the display first as Display0, but that didn’t make a difference in this case.
Attaching my nvidia-bug-report.sh in case that helps as well.
Any help figuring this out would be greatly appreciated.
nvidia-bug-report.log.gz (394.5 KB)
