Continuous HTTP 429 (Too Many Requests) on single API calls even with newly generated keys
Body:
Hello NVIDIA Community,
I am consistently encountering an HTTP 429 rate limit error when using the NVIDIA NIM API, even though I am only sending a single request.
To resolve this, I have already generated a brand new API key, completely restarted my environment to clear any potential token/key cache, and ensured that no background scripts or loops are running. However, the exact same error persists immediately upon the very first request with the new key.
Here are the error details from my logs:
  • Category: rate_limit
  • Mapped Message: Provider rate limit reached. Please retry shortly.
  • Upstream Error: {"status":429,"title":"Too Many Requests"}
  • Request ID: req_0a892258dc164bf39f267e95dd4e1ef9
Could an engineer please check if my account is hitting a stuck account-level rate limit or if there is a severe backend/upstream provider outage affecting the developer free-tier pool at the moment?
Thank you for your assistance!
The limit is being applied at the account level, not at the key level. You need to wait a few minutes before trying again, because with each new request made while still blocked, your lockout duration increases (Exponential Backoff). If you are using CLI tools such as opencode, don’t be fooled—they usually make parallel calls under the hood unless you set the concurrency to 1.
