After flashing JP5.1.1, the system boots into the OS without issues.
However, if the reboot command is executed four or more times in quick succession,
the system fails to find /dev/mmcblk0p1 during boot, and it can’t loading to the OS.
Could you please provide some suggestions?
The complete Debug UART log is attached for reference.
[ 9.700649] ALSA device list:
[ 9.700746] No soundcards found.
[ 9.701471] Freeing unused kernel memory: 3968K
[ 9.701653] Run /init as init process
[ 9.713311] Root device found: initrd
[ 9.713759] Mount initrd as rootfs and enter recovery mode
Finding OTA work dir on external storage devices
Checking whether device /dev/mmcblk?p1 exist
Looking for OTA work directory on the device(s): /dev/mmcblk0p1
Checking whether device /dev/sd?1 exist
Device /dev/sd?1 does not exist
Checking whether device /dev/nvme?n1p1 exist
Device /dev/nvme?n1p1 does not exist
Finding OTA work dir on internal storage device
[ 9.748753] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
OTA work directory /mnt/ota_work is not found on /dev/mmcblk0p1
OTA work directory is not found on internal and external storage devices
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.0#
If the system fails to load the OS, I have to reflash the AGX Orin. After reflashing, the AGX Orin boots into the OS successfully.
The nv-l4t-bootloader-config.service is working as shown in the message below.
nvidia@tegra-ubuntu:~$ systemctl status nv-l4t-bootloader-config.service
● nv-l4t-bootloader-config.service - Configure bootloader service
Loaded: loaded (/etc/systemd/system/nv-l4t-bootloader-config.service; enabled; vendor preset: enabled)
Active: inactive (dead) since Mon 2024-06-03 01:53:43 UTC; 26min ago
Process: 2773 ExecStart=/opt/nvidia/l4t-bootloader-config/nv-l4t-bootloader-config.sh -v (code=exited, status=0/SUCCE>
Main PID: 2773 (code=exited, status=0/SUCCESS)
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[3070]: TEGRA_EMMC_ONLY false
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[3070]: TEGRA_CHIPID 0x23
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[3070]: TEGRA_OTA_BOOT_DEVICE /dev/mtdblock0
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[3070]: TEGRA_OTA_GPT_DEVICE /dev/mtdblock0
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[2773]: Info: Write TegraPlatformCompatSpec with 3701--0005--1--n>
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[2773]: Info. Uninstalling mtdblock.
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[2773]: Info. Verifying boot status.
Jun 03 01:53:42 tegra-ubuntu nv-l4t-bootloader-config.sh[3076]: Info: variable BootChainFwStatus is not found.
Jun 03 01:53:43 tegra-ubuntu systemd[1]: nv-l4t-bootloader-config.service: Succeeded.
Jun 03 01:53:43 tegra-ubuntu systemd[1]: Finished Configure bootloader service.
...skipping...
I tried monitoring the nv-l4t-bootloader-config service through 5 reboots.
I found that after booting into the OS, it takes about one minute for the nv-l4t-bootloader-config.service to complete.
I would like to ask for advice on how to revert to direct boot.
When is the correct timing to press ESC?
Where should I press ESC? Should I do it in the debug UART console?
