Contradiction in documentation of TX1 carrier board
I’ve stumbled over an issues in the documentation.
I’m designing a custom carrier board for TX1 SOM.
The documentation of the SATA connector has a contradiction between the OEM implementation manual and the schematics of the TX! carrier board.
The OEM manual says pin 10 of the SATA connector should be left unused.
in the schematics of the TX1 carrier, this pin is connected to pin D47 of the TX1.
The OEM manual clearly states that pin D47 is reserved and should be left unused.
Would appreciate any input here.
Thanx
Moshe
Hi MosheMago,
The SATA_DEV_DLP function was not supported for Jetson TX1, please take OEM DG as standard.
