Hey i am using xavier agx DK , I am using a mimo um-1080ch-of which is connected through HDMI . I want to control the brightness of the screen but ddcutil doesnt find any display connected
echo 1 > /sys/kernel/debug/tegra_hdmi/ddc_power_toggle
Run this and try the ddcutil again.
actually its a permission denied error
You need to run as a root.
hi @WayneWWW ,
I was running it as root ,but i found the solution here for it Permission denied on /sys/kernel/debug its working now thanks for your help
Actually, if you need to follow that command to make it work… you better check your installation for rootfs and BSP…
IMO this should not be needed.
