Controlled impedance for PCIe on carrier board
Hi Mike,
The impedance is to match that of module routing, there are +/-15% tolerance for it, 95 ohm is in the range.
Generally if the GPS lines are on the same layer and nearby, a shielding GND line to isolate from PCIe lines is necessary, if on the different layers, the covering GND plane is necessary.
