I get an error when trying to do a 3d convolution with strides = 2 and postPadding = 1. The terminal says
WARNING: Setting layouts of network and plugin input/output tensors to linear, as 3D operators are found and 3D non-linear IO formats are not supported, yet.
ERROR: C:\source\builder\cudnnBuilderUtils.cpp (364) - Cuda Error in nvinfer1::cudnn::findFastestTactic: 77 (an illegal memory access was encountered)
ERROR: C:\source\rtSafe\safeRuntime.cpp (32) - Cuda Error in nvinfer1::internal::DefaultAllocator::free: 77 (an illegal memory access was encountered)
Below is a minimal example for the error
#include <NvInfer.h>
#include <iostream>
#include <vector>
using namespace std;
using namespace nvinfer1;
class StdOutLogger : public ILogger
public:
StdOutLogger(ILogger::Severity severity)
: mReportedSeverity(severity)
void log(ILogger::Severity severity, char const* message) override
if (severity > mReportedSeverity)
return;
switch (severity)
case Severity::kINTERNAL_ERROR: std::cerr << "INTERNAL_ERROR: "; break;
case Severity::kERROR: std::cerr << "ERROR: "; break;
case Severity::kWARNING: std::cerr << "WARNING: "; break;
case Severity::kINFO: std::cerr << "INFO: "; break;
default: std::cerr << "UNKNOWN: "; break;
std::cerr << message << std::endl;
private:
ILogger::Severity mReportedSeverity;
Weights getKernelWeights(int inputChannel, int filter, int kernelsize)
Weights weights;
weights.count = inputChannel * filter * kernelsize * kernelsize * kernelsize;
weights.type = DataType::kFLOAT;
vector<float> values(weights.count);
for (auto i = 0u; i < values.size(); ++i)
values[i] = i;
weights.values = values.data();
return weights;
Weights getBiasWeights()
Weights weights;
weights.count = 2;
vector<float> values{ -1.f, -2.f };
return weights;
int main()
StdOutLogger logger(ILogger::Severity::kINFO);
auto builder = createInferBuilder(logger);
auto network = builder->createNetwork();
auto convBiasWeights = getBiasWeights();
auto input = network->addInput("input", DataType::kFLOAT, Dims4{ 1, 64, 64, 64 });
auto conv = network->addConvolutionNd(*input, 2, Dims3{ 3, 3, 3}, getKernelWeights(1, 2, 3), convBiasWeights);
conv->setPrePadding(Dims3{ 1, 1, 1 });
conv->setPostPadding(Dims3{ 1, 1, 1 });
auto conv2 = network->addConvolutionNd(*conv->getOutput(0), 2, Dims3{ 3, 3, 3 }, getKernelWeights(2, 2, 3), convBiasWeights);
conv2->setStrideNd(Dims3{ 2, 2, 2 });
conv2->setPrePadding(Dims3{ 0, 0, 0 });
conv2->setPostPadding(Dims3{ 1, 1, 1 });
network->markOutput(*conv2->getOutput(0));
builder->setMaxBatchSize(1);
builder->setMaxWorkspaceSize(static_cast<size_t>(1) << 33);
auto engine = builder->buildCudaEngine(*network);
engine->destroy();
network->destroy();
builder->destroy();
return 0;
PS: Maybe this issue is related to https://devtalk.nvidia.com/default/topic/1064564/tensorrt/dynamic-input-and-convolution/
