Hi, all
- convert tensorflow 1 model to onnx model
python nvidia_xavier_nx_convertor.py -ot onnx -if /home/yons/workspace/models/tf1/shuffleNet/ckpt/shufflene_v2_1.0.ckpt.meta -op /home/yons/workspace/models/tf1/shuffleNet/ckpt/onnx -in Placeholder:0 -on shuffle_netv2/dense/MatMul:0 --inputs-as-nchw Placeholder:0
- scripts
nvidia_xavier_nx_converter.py
try:
import tensorflow as tf
from tensorflow.contrib import * # this include isn't used but solves some common tf errors
except ImportError:
print("please install the tensorflow library")
try:
import tf2onnx
except ImportError:
print("please install tf2onnx model")
import uff # to convert the graph from a serialized frozen TensorFlow model to UFF.
import os
# import tf2onnx
import subprocess
import argparse
class tensorrt_converter():
def __init__(self, input_type, output_type, input_nodes, output_nodes, input_file, output_path):
self.output_type = output_type
self.input_type = input_type
self.input_nodes = input_nodes
self.output_nodes = output_nodes
self.input_file = input_file
self.output_path = output_path
def convert(self,kwargs):
conver input model trained by AI framework to inference model supported by tensorrt
if self.input_type == "caffe":
if(os.path.isdir(self.input_file)):
filelist = os.listdir(self.input_file)
filename_extension = []
for filename in filelist:
if filename_extension.empty():
filename_extension.append(filename.split('.')[-1])
for file_ex in filename_extension:
if filename.split('.')[-1] != file_ex:
if (filename_extension[0] == 'caffemodel' and filename_extension[-1] == 'prototxt') or (filename_extension[0] == 'prototxt' and filename_extension[-1] == 'caffemodel'):
return True
else:
print("the caffe model need multiply files, please input file directory.")
return False
return True
if self.input_type == "pytorch":
pass
if self.input_type == "tensorflow":
if self.output_type == 'uff':
if not self.tf2uff():
return False
if self.output_type == 'onnx':
if not self.to_onnx('tensorflow',kwargs):
return False
if self.input_type == "paddlepaddle":
pass
if self.input_type == "mindspore":
pass
return True
def tf2uff(self):
convert the tensorflow model to uff up to tensorflow model format
if(self.get_tf_file_type(self.input_file) == 'frozen_file'):
print("convert pb tp uff")
# process_result = uff.from_tensorflow_frozen_model(frozen_file = self.input_file, output_nodes = self.output_nodes,preprocessor=None, output_filename = os.path.join(self.output_path, os.path.basename(self.input_file).split('.')[0] + ".uff"))
process_result = uff.from_tensorflow_frozen_model(frozen_file = self.input_file, preprocessor=None, output_filename = os.path.join(self.output_path, os.path.basename(self.input_file).split('.')[0] + ".uff"))
if not process_result:
return False
elif(self.get_tf_file_type(self.input_file) == 'checkpoint'):
#Load checkpoint
checkpoint = tf.train.get_checkpoint_state(self.input_file)
input_checkpoint = checkpoint.model_checkpoint_path
#Devices should be cleared to allow Tensorflow to control placement of graph when loading on different machines
saver = tf.train.import_meta_graph(input_checkpoint + '.meta', clear_devices=True)
if not saver:
return False
#Get the graph_def
graph = tf.get_default_graph()
input_graph_def = graph.as_graph_def()
#output names array
output_nodes_names = self.output_nodes
with tf.Session(graph=graph) as sess:
saver.restore(sess, input_checkpoint)
frozen_graph = tf.graph_util.convert_variables_to_constants(sess, input_graph_def, output_nodes_names)
frozen_graph = tf.graph_util.remove_training_nodes(frozen_graph)
uff_model = uff.from_tensorflow(frozen_graph, output_nodes_names, output_filename = os.path.join(self.output_path, os.path.split(self.input_file)[1] + ".uff"))
if uff_model :
return False
else:
print("Error: converter tensorflow model to uff format")
return False
return True
def to_onnx(self, input_type, kwargs):
converter imput type model to onnx type model
# convert list to dictionary
kwargs_dict = dict(zip(kwargs[0::2],kwargs[1::2]))
if input_type == 'tensorflow':
inputs_as_nchw=''
for k, v in kwargs_dict.items():
if k == "--inputs-as-nchw":
inputs_as_nchw = v
print(self.get_tf_file_type(self.input_file))
if self.get_tf_file_type(self.input_file) == 'checkpoint':
cmdl = ['-m', 'tf2onnx.convert', '--checkpoint',
"%s" % self.input_file, '--output', "%s" % os.path.join(self.output_path, os.path.split(self.input_file)[1] + ".onnx"),
'--opset', str(9),
'--inputs', "%s" % self.input_nodes,
'--outputs', "%s" % self.output_nodes,
elif self.get_tf_file_type(self.input_file) == 'frozen_file':
cmdl = ['-m', 'tf2onnx.convert', '--graphdef',
"%s" % self.input_file, '--output', "%s" % os.path.join(self.output_path, os.path.basename(self.input_file).split('.')[0] + ".onnx"),
'--opset', str(9),
if inputs_as_nchw is not '':
cmdl.append('--inputs-as-nchw')
cmdl.append(inputs_as_nchw)
else:
print("input checkpoint file format or frozen_file format")
return
final_cmdl = ['python ']
final_cmdl.extend(cmdl)
cmd_str = ' '.join(final_cmdl)
os.system(cmd_str)
if type == 'paddlepaddle':
pass
if type == 'pytorch':
pass
def get_tf_file_type(self, input):
get the input tensorflow type
# if not os.path.exists(input):
# print("the files not exist")
# return False
# if os.path.isdir(input):
# filelist = os.listdir(input)
# filename_extension = []
# for filename in filelist:
# filename_extension.append(filename.split('.')[-1])
# # duplicate removal
# file_ext_unique= list(set(filename_extension))
# for file_ext_name in file_ext_unique:
# if 'data' in file_ext_name:
# if 'meta' in file_ext_unique:
# return "checkpoint"
if os.path.isfile(input):
if 'pb' == os.path.basename(input).split(".")[-1]:
# if 'pb' == os.path.split(input, '.')[-1]:
return 'frozen_file'
if 'meta' == os.path.basename(input).split('.')[-1]:
return 'checkpoint'
def parse_args():
""" Parses command line arguments. """
parser = argparse.ArgumentParser()
parser.add_argument(
'-it',
"--input_type",
type=str,
default='tensorflow',
help="model trained format "
'-ot',
"--output_type",
type=str,
default='uff',
help="model inferenced format in nvidia tensorrt"
'-in',
"--input_nodes",
type=str,
default=[ ],
help="input nodes name (list)"
'-on',
"--output_nodes",
type=str,
default=[ ],
help="output nodes name(list)"
'-if',
"--input_file",
type=str,
required=True,
help="input model fils. if the model format needs multiple files to save model infromation, please input the directory of model files. otherwise, plese input the absolute file name."
'-op',
"--output_path",
type=str,
required=True,
help="output inference model path. The inference model genereated file name prefix is same as the input model file name. If the input_flie is directory name, the generated file name prefix is the directory name. "
return parser.parse_known_args()
if __name__ == "__main__":
convert_args, unparsed = parse_args()
to=tensorrt_converter(convert_args.input_type, convert_args.output_type,
convert_args.input_nodes, convert_args.output_nodes,
convert_args.input_file, convert_args.output_path
to.convert(unparsed)
the model from [the link]( models.rar_免费高速下载|百度网盘-分享无限制 (baidu.com))
I can got the onnx model, and inference the model with onnxruntime successfully
the scripts
import onnxruntime as rt
import numpy as np
input_tensor = np.random.random((1,224,224,3)).astype(np.float32)
session = rt.InferenceSession("/home/yons/workspace/models/tf1/shuffleNet/ckpt/onnx/shufflene_v2_1.0.ckpt.meta.onnx")
input_name = session.get_inputs()[0].name
print("input_name : ", input_name)
input_shape = session.get_inputs()[0].shape
print("input_shape : ", input_shape)
output_name = session.get_outputs()[0].name
print("output_name : ", output_name)
output_shape = session.get_outputs()[0].shape
print("output_shape : ", output_shape)
res = session.run([output_name],{input_name:input_tensor })
out = np.array(res)
print(out)
- inference the onnx model in tensorrt ,
Error
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/conv2d_bn__re_lu/conv2d/Conv2D__7 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__558 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit2/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit2/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit2/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 19) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 20) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 21) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 21) [Concatenation] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 22) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 23) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/split is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_4/conv2d_4/Conv2D__67 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_4/conv2d_4/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_4/conv2d_4/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_4/activation_4/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_4/activation_4/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/depthwise_conv2d_bn_2/depthwise_conv2d_2/depthwise does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/depthwise_conv2d_bn_2/depthwise_conv2d_2/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_5/conv2d_5/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_5/conv2d_5/Conv2D is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_5/batch_normalization_8/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_5/batch_normalization_8/FusedBatchNorm is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_5/activation_5/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/conv2d_bn__re_lu_5/activation_5/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__560 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__566 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 39) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 40) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 41) [Concatenation]: DLA only supports concatenation on the C dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 41) [Concatenation] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 42) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 43) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/split is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_6/conv2d_6/Conv2D__96 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_6/conv2d_6/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_6/conv2d_6/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_6/activation_6/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_6/activation_6/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/depthwise_conv2d_bn_3/depthwise_conv2d_3/depthwise does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/depthwise_conv2d_bn_3/depthwise_conv2d_3/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_7/conv2d_7/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_7/conv2d_7/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_7/batch_normalization_11/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_7/batch_normalization_11/FusedBatchNorm is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_7/activation_7/Relu does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/conv2d_bn__re_lu_7/activation_7/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__568 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/concat does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__574 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_1/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 59) [Shape] device type to GPU.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 60) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 61) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 61) [Concatenation] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 62) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 63) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/split is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_8/conv2d_8/Conv2D__125 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_8/conv2d_8/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_8/conv2d_8/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_8/activation_8/Relu does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_8/activation_8/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/depthwise_conv2d_bn_4/depthwise_conv2d_4/depthwise does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/depthwise_conv2d_bn_4/depthwise_conv2d_4/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_9/conv2d_9/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_9/conv2d_9/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_9/batch_normalization_14/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_9/batch_normalization_14/FusedBatchNorm is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_9/activation_9/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/conv2d_bn__re_lu_9/activation_9/Relu is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer Transpose__576 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/concat is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer Transpose__582 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/Reshape is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage/shufflenet_unit1_2/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__732 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer Transpose__590 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit2_1/Reshape is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit2_1/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit2_1/Reshape_1 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 95) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 96) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 97) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 97) [Concatenation] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 98) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 99) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/split is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_13/conv2d_13/Conv2D__202 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_13/conv2d_13/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_13/conv2d_13/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_13/activation_13/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_13/activation_13/Relu is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/depthwise_conv2d_bn_7/depthwise_conv2d_7/depthwise does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/depthwise_conv2d_bn_7/depthwise_conv2d_7/depthwise is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_14/conv2d_14/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_14/conv2d_14/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_14/batch_normalization_22/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_14/batch_normalization_22/FusedBatchNorm is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_14/activation_14/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/conv2d_bn__re_lu_14/activation_14/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__592 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__598 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_3/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 115) [Shape] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 116) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 117) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 117) [Concatenation] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 118) [Constant] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 119) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/split is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_15/conv2d_15/Conv2D__231 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_15/conv2d_15/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_15/conv2d_15/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_15/activation_15/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_15/activation_15/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/depthwise_conv2d_bn_8/depthwise_conv2d_8/depthwise does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/depthwise_conv2d_bn_8/depthwise_conv2d_8/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_16/conv2d_16/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_16/conv2d_16/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_16/batch_normalization_25/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_16/batch_normalization_25/FusedBatchNorm is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_16/activation_16/Relu does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/conv2d_bn__re_lu_16/activation_16/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__600 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/concat does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__606 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/Reshape is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_4/Reshape_1 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 135) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 136) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 137) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 137) [Concatenation] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 138) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 139) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/split is not supported on DLA, falling back to GPU.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_17/conv2d_17/Conv2D__260 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_17/conv2d_17/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_17/conv2d_17/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_17/activation_17/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_17/activation_17/Relu is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/depthwise_conv2d_bn_9/depthwise_conv2d_9/depthwise does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/depthwise_conv2d_bn_9/depthwise_conv2d_9/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_18/conv2d_18/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_18/conv2d_18/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_18/batch_normalization_28/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_18/batch_normalization_28/FusedBatchNorm is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_18/activation_18/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/conv2d_bn__re_lu_18/activation_18/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__608 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/concat does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__614 is not supported on DLA, falling back to GPU.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_5/Reshape_1 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 155) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 156) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 157) [Concatenation]: DLA only supports concatenation on the C dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 157) [Concatenation] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 158) [Constant] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 159) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/split is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/split_1 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_19/conv2d_19/Conv2D__289 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_19/conv2d_19/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_19/conv2d_19/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_19/activation_19/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_19/activation_19/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/depthwise_conv2d_bn_10/depthwise_conv2d_10/depthwise does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/depthwise_conv2d_bn_10/depthwise_conv2d_10/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_20/conv2d_20/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_20/conv2d_20/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_20/batch_normalization_31/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_20/batch_normalization_31/FusedBatchNorm is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_20/activation_20/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/conv2d_bn__re_lu_20/activation_20/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__616 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__622 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_6/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 175) [Shape] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 176) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 177) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 177) [Concatenation] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 178) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 179) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/split is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_21/conv2d_21/Conv2D__318 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_21/conv2d_21/Conv2D does not support dynamic shapes in any dimension.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_21/conv2d_21/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_21/activation_21/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_21/activation_21/Relu is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/depthwise_conv2d_bn_11/depthwise_conv2d_11/depthwise does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/depthwise_conv2d_bn_11/depthwise_conv2d_11/depthwise is not supported on DLA, falling back to GPU.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_22/conv2d_22/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_22/conv2d_22/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_22/batch_normalization_34/FusedBatchNorm does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_22/batch_normalization_34/FusedBatchNorm is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_22/activation_22/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/conv2d_bn__re_lu_22/activation_22/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__624 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__630 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/Reshape is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_7/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 195) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 196) [Constant] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] (Unnamed Layer* 197) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 197) [Concatenation] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 198) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 199) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/split is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/split_1 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_23/conv2d_23/Conv2D__347 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_23/conv2d_23/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_23/conv2d_23/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_23/activation_23/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_23/activation_23/Relu is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/depthwise_conv2d_bn_12/depthwise_conv2d_12/depthwise does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/depthwise_conv2d_bn_12/depthwise_conv2d_12/depthwise is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_24/conv2d_24/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_24/conv2d_24/Conv2D is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_24/batch_normalization_37/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_24/batch_normalization_37/FusedBatchNorm is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_24/activation_24/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/conv2d_bn__re_lu_24/activation_24/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__632 is not supported on DLA, falling back to GPU.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__638 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/Reshape is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_8/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 215) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 216) [Constant] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] (Unnamed Layer* 217) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 217) [Concatenation] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 218) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 219) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/split is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_25/conv2d_25/Conv2D__376 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_25/conv2d_25/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_25/conv2d_25/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_25/activation_25/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_25/activation_25/Relu is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/depthwise_conv2d_bn_13/depthwise_conv2d_13/depthwise does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/depthwise_conv2d_bn_13/depthwise_conv2d_13/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_26/conv2d_26/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_26/conv2d_26/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_26/batch_normalization_40/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_26/batch_normalization_40/FusedBatchNorm is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_26/activation_26/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/conv2d_bn__re_lu_26/activation_26/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__640 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__646 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_1/shufflenet_unit1_9/Reshape_1 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer Transpose__736 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer Transpose__654 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit2_2/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit2_2/transpose is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit2_2/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 251) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 252) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 253) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 253) [Concatenation] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 254) [Constant] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 255) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/split is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_30/conv2d_30/Conv2D__453 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_30/conv2d_30/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_30/conv2d_30/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_30/activation_30/Relu does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_30/activation_30/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/depthwise_conv2d_bn_16/depthwise_conv2d_16/depthwise does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/depthwise_conv2d_bn_16/depthwise_conv2d_16/depthwise is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_31/conv2d_31/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_31/conv2d_31/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_31/batch_normalization_48/FusedBatchNorm does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_31/batch_normalization_48/FusedBatchNorm is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_31/activation_31/Relu does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/conv2d_bn__re_lu_31/activation_31/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__656 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__662 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/Reshape is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_10/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 271) [Shape] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 272) [Constant] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] (Unnamed Layer* 273) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 273) [Concatenation] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 274) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 275) [Gather] device type to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/split is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_32/conv2d_32/Conv2D__482 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_32/conv2d_32/Conv2D does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_32/conv2d_32/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_32/activation_32/Relu does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_32/activation_32/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/depthwise_conv2d_bn_17/depthwise_conv2d_17/depthwise does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/depthwise_conv2d_bn_17/depthwise_conv2d_17/depthwise is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_33/conv2d_33/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_33/conv2d_33/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_33/batch_normalization_51/FusedBatchNorm does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_33/batch_normalization_51/FusedBatchNorm is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_33/activation_33/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/conv2d_bn__re_lu_33/activation_33/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__664 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/concat does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/concat is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer Transpose__670 is not supported on DLA, falling back to GPU.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/Reshape is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/transpose is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_11/Reshape_1 is not supported on DLA, falling back to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 291) [Shape] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 292) [Constant] device type to GPU.
[W] [TRT] (Unnamed Layer* 293) [Concatenation]: DLA only supports concatenation on the C dimension.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 293) [Concatenation] device type to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 294) [Constant] device type to GPU.
[W] [TRT] DLA only supports FP16 and Int8 precision type. Switching (Unnamed Layer* 295) [Gather] device type to GPU.
[W] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/split is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/split_1 is not supported on DLA, falling back to GPU.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/conv2d_bn__re_lu_34/conv2d_34/Conv2D__511 is not supported on DLA, falling back to GPU.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/conv2d_bn__re_lu_34/conv2d_34/Conv2D does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/conv2d_bn__re_lu_34/conv2d_34/Conv2D is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/conv2d_bn__re_lu_34/activation_34/Relu does not support dynamic shapes in any dimension.
[W] [TRT] Default DLA is enabled but layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/conv2d_bn__re_lu_34/activation_34/Relu is not supported on DLA, falling back to GPU.
[W] [TRT] DLA Layer shuffle_netv2/shufflenet_stage_2/shufflenet_unit1_12/depthwise_conv2d_bn_18/depthwise_conv2d_18/depthwise does not support dynamic shapes in any dimension.
[07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] [07/29/2021-19:44:10] The engine create failed.
thanks for your time!
