Note: For any Isaac Lab topics, please submit your topic to its GitHub repo ( GitHub - isaac-sim/IsaacLab: Unified framework for robot learning built on NVIDIA Isaac Sim ) following the instructions provided on Isaac Lab’s Contributing Guidelines ( Contribution Guidelines — Isaac Lab Documentation ).
Isaac Sim Version
5.0.0
4.5.0
4.2.0
Operating System
Windows 11
GPU Information
- Model: RTX 6000 ADA
- Driver Version: 573.44
Topic Description
Cesium for Omniverse v0.25.0 fails to render 3D Tiles in Isaac Sim 5.0 (Kit 106.x). Tileset.json appears in Stage but geometry and textures are missing or heavily distorted. Console shows curl and 404 errors when accessing local or Cesium Ion assets.
Detailed Description
I am encountering persistent issues while using the Cesium for Omniverse extension inside Isaac Sim (tested on versions 5.0.0, 4.5.0, and 4.2.0) on Windows 11 with an NVIDIA RTX 6000 ADA GPU (driver 573.44).
When I attempt to load Cesium 3D Tilesets (tileset.json) either locally or via Cesium Ion, the extension partially initializes, and the tileset node appears in the Stage tree — however, the actual geometry is not rendered in the viewport or appears heavily distorted / incomplete.
Steps to Reproduce
- Install Isaac Sim 5.0.0 (and tested also with 4.5.0).
- Enable Cesium for Omniverse and USD Plugins extensions.
- Restart Isaac Sim (Fabric Scene Delegate enabled).
- Load a Cesium 3D Tileset either:
Locally:
file:///D:/Abu/tileset.json, or -
Via Cesium Ion: Asset ID
4029015.
- Observe console output and viewport behavior.
Error Messages
[cesium.omniverse.plugin] Errors when loading tileset: curl: Couldn’t read a file:// file
[cesium.omniverse.plugin] Received status code 404 for asset response https://api.cesium.com/v1/assets/4029015/endpoint…
[cesium.omniverse.plugin] An unexpected error occurred when loading tile: curl: URL using bad/illegal format or missing URL
[cesium.omniverse.plugin] Failed to startup Python extension.
[carb.scripting-python.plugin] RuntimeError: Failed to acquire interface
[omni.anim.navigation.meshtools] Could not load dynamic library … meshtools.plugin.dll
Screenshots or Videos
Additional Information
What I’ve Tried
Verified Cesium Ion connection (asset visible in panel).
Tested both
file:///and Ion imports. -
Checked that all
.glb,.subtree, and.jsonfiles exist and are accessible. -
Reinstalled Cesium for Omniverse (v0.25.0) and ensured compatibility with Kit 106.x.
Confirmed NVIDIA driver 573.44 installed.
Tested across Isaac Sim versions 4.2.0, 4.5.0, and 5.0.0.
Adjusted
Maximum Screen Space Error, lighting, and georeference scale — no change.Expected Behavior
The tileset should:
Load successfully into the Omniverse viewport.
Display the full 3D geometry and textures as seen in Cesium Ion or CesiumJS.
Allow manipulation and alignment with Isaac Sim’s world coordinates (via CesiumGeoreference).
Actual Behavior-
The tileset node appears in the Stage hierarchy, but:
The model does not render in the viewport, or
Geometry appears broken / incomplete, missing large sections, and lacking texture detail.
When loaded via Cesium Ion, the import completes, but no visual output appears at all.
Local path loading fails with
curl: Couldn't read a file:// file, even though the file exists and permissions are correct. -
The console repeatedly reports
404andcurlerrors.
Related Issues
Similar to other reports where Cesium 3D Tiles load but do not render due to path or georeference issues in Isaac Sim (e.g., missing Fabric delegate or Ion 404).
Additional Context
The same tileset (tileset.json) loads correctly in CesiumJS / Cesium Ion web viewer, confirming that the dataset itself is valid.
The rendering or data access problem appears specific to Cesium for Omniverse’s integration with Isaac Sim (Kit 106.x).
