Conversion of tensorflow grapgh to tensorrt
I have used the TensorFlow container from NGC for converting the tf graph to the TensorRT graph. But while converting, the process got aborted due to the core dumped. I am using the virtual GPU machine(Tesla M60 ) from azure. Is there any hardware specification for the optimization of the model?
I am attaching screenshots for the same.
Thanks in Advance…!!!
have you check whether the GPU compute capacity match the TensorRT, and other lib, such as cuda, cudnn version compatible?
No, how should I get that information?
you can google the GPU compute capacity and the cuda version. The have the matching lists!
