Convert custom data to TFRecords error MaskRCNN
• Hardware T4
• Network Type Mask_rcnn
• TLT Version Tao 3.2.55
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
Hello professor:
I use the mask RCNN by notebook. I hope train the model with my dataset. So at labeled the image by labelme, and translate them into coco. I hope to use the code"tao mask_rcnn dataset_convert" to translate it into tfrecord.
However I meet the problem:
tensorflow.python.framework.errors_impl.NotFoundError: /workspace/tao-experiments/data/raw-data/train2017/JPEGImages\1.jpg; No such file or directory
my Mounts is
the path of the image is
the error is
Thank you very much.
Can you run below command to check if the image is available?
$ tao mask_rcnn run ls /workspace/tao-experiments/data/raw-data/train2017/JPEGImages/1.jpg
I run the code and get
It seems can work.
I find a problem: the error is
“tensorflow.python.framework.errors_impl.NotFoundError: /workspace/tao-experiments/data/raw-data/train2017/JPEGImages\1.jpg; No such file or directory”
here, the “/JPEGImages\1.jpg” is not “/JPEGImages/1.jpg”.
Maybe I solved it.
Because the coco json is produced in Windows, so the path is “\”, I modified it . It seems can work.
