Description
For a while, I’m trying to convert the Hourglass model of CenterNet to TensorRT through onnx format. Below, I attached a part of the script that I used to convert the Hourglass model to onnx format:
def hourglass_forward(self, x):
inter = self.pre(x)
ret = []
for ind in range(self.nstack):
kp, cnv_ = self.kps[ind], self.cnvs[ind]
kp = kp_(inter)
cnv = cnv_(kp)
out = []
for head in self.heads:
layer = self.getattr(head)[ind]
y = layer(cnv)
ret.append(y)
if ind < self.nstack - 1:
inter = self.inters_[ind](inter) + self.cnvs_[ind](cnv)
inter = self.relu(inter)
inter = self.inters[ind](inter)
return ret
opt = opts().init()
opt.arch = 'hourglass_104'
opt.heads = OrderedDict([('hm', 80), ('reg', 2), ('wh', 2)])
opt.head_conv = 256 if 'hourglass' in opt.arch else 64
print(opt)
model = create_model(opt.arch, opt.heads, opt.head_conv)
model.forward = MethodType(forward[opt.arch.split('')[0]], model)
load_model(model, 'ctdet_coco_hg.pth')
model.eval()
model.cuda()
input = torch.zeros([1, 3, 512, 512]).cuda()
onnx.export(model, input, "ctdet_coco_hg.onnx", verbose=True,operator_export_type=OperatorExportTypes.ONNX)
It seems that there is some mistakes in my script but the conversion to onnx format done. However, when I tried to apply the first step of TensorRT to generate the engine, it shows these errors:
WARNING: ONNX model has a newer ir_version (0.0.4) than this parser was built against (0.0.3).
WARNING: Your ONNX model has been generated with INT64 weights, while TensorRT does not natively support INT64. Attempting to cast down to INT32.
Successfully casted down to INT32.
While parsing node number 208 [Gather]:
3
ERROR: …/onnx2trt_utils.hpp:335 In function convert_axis:
[8] Assertion failed: axis >= 0 && axis < nbDims
ERROR: failed to parse onnx file
There is any suggestion about these errors?
Environment
TensorRT Version: 6.0.1.5
GPU Type: RTX 6000
Nvidia Driver Version: 455.32
CUDA Version: 10.1
CUDNN Version: 7.5.0
Operating System + Version: Ubunu 18.04
Python Version (if applicable): Python 3.6.0
TensorFlow Version (if applicable): 2.0.0
PyTorch Version (if applicable): 1.2.0
