in the codec sdk, you provide the api to convert nv12 to rgba
void Nv12ToBgra32(uint8_t *dpNv12, int nNv12Pitch, uint8_t *dpBgra, int nBgraPitch, int nWidth, int nHeight, int iMatrix);
But I don’t want the alpha channel
So I create
union BGR24 {
uchar3 v;
struct {
uint8_t b, g, r
} c;
And modify YuvToRgbKernel as follows
void Nv12ToBgra32(uint8_t *dpNv12, int nNv12Pitch, uint8_t *dpBgra, int nBgraPitch, int nWidth, int nHeight, int iMatrix) {
SetMatYuv2Rgb(iMatrix);
YuvToRgbKernel<uchar2, BGR24, uchar3>
<<<dim3((nWidth + 63) / 32 / 2, (nHeight + 3) / 2 / 2), dim3(32, 2)>>>
(dpNv12, nNv12Pitch, dpBgra, nBgraPitch, nWidth, nHeight);
template<class YuvUnitx2, class Rgb, class RgbIntx2>
__global__ static void YuvToRgbKernel(uint8_t *pYuv, int nYuvPitch, uint8_t *pRgb, int nRgbPitch, int nWidth, int nHeight) {
int x = (threadIdx.x + blockIdx.x * blockDim.x) * 2;
int y = (threadIdx.y + blockIdx.y * blockDim.y) * 2;
if (x + 1 >= nWidth || y + 1 >= nHeight) {
return;
uint8_t *pSrc = pYuv + x * sizeof(YuvUnitx2) / 2 + y * nYuvPitch;
uint8_t *pDst = pRgb + x * sizeof(Rgb) + y * nRgbPitch;
YuvUnitx2 l0 = *(YuvUnitx2 *)pSrc;
YuvUnitx2 l1 = *(YuvUnitx2 *)(pSrc + nYuvPitch);
YuvUnitx2 ch = *(YuvUnitx2 *)(pSrc + (nHeight - y / 2) * nYuvPitch);
*(RgbIntx2 *)pDst = YuvToRgbForPixel<Rgb>(l0.x, ch.x, ch.y).v;
*(RgbIntx2 *)(pDst + 1) = YuvToRgbForPixel<Rgb>(l0.y, ch.x, ch.y).v;
*(RgbIntx2 *)(pDst + nRgbPitch) = YuvToRgbForPixel<Rgb>(l1.x, ch.x, ch.y).v;
*(RgbIntx2 *)(pDst + nRgbPitch + 1) = YuvToRgbForPixel<Rgb>(l1.y, ch.x, ch.y).v;
but this does not work…
I am not familiar with nv12.
Any advise?
