I made a redaction app using DeepStream and am trying to follow this tutorial to optimize the tutorial’s pre-trained model for deployment in my app, instead of the fp32 one am using currently (from this old redaction repo). I have a couple questions:
- What is the best way to convert the .pth file to .onnx on Xavier, since the retinanet-examples Python package won’t install? Can I do this on a pair of 1080s instead?
- Same as above, to perform calibration for the Xavier, should I do the int8 calibration on the Xavier itself or on x86 Nvidia?
- My app accepts n number of sources and sets the batch-size at runtime to match. When converting to a engine with tensorrt-utils’s onnx_to_tensorrt.py, should I use the --explicit-batch option to generate an optimization profile? Or do I need to do somethign else and have DeepStream do the job for me?
Moving to Jetson Xavier forum so that Jetson team can take a look.
1. You can convert the model into onnx with pyTorch frameworks directly:
https://pytorch.org/docs/stable/onnx.html
To convert a model into onnx is platform independent.
However, you will need to apply the conversion from onnx into TensorRT engine on the device directly.
2. Please apply the INT8 calibration on the device.
3. YES. Please use it if the input sources number is fixed.
You can find more information in this document:
1. Dynamic batch = explicit batch = set it as -1
2. No needed
3. You will need to specify the range of dimension when building.
This is because the TensorRT choose inference algorithm in the building stage.
The tensor size change is limited due to the pre-allocated memory.
Thanks for asking my questions! I think I can figure out the rest from the documentation and source.
Feel free to file a topic if you need help. : )
Thanks, Aasta :)
I am taking one of the “Optimization and Deployment of TensorFlow Models with TensorRT” GTC course tomorrow, but if anything isn’t covered I will certainly post a topic.
Edit: I am very silly. The class is Tuesday April 7. Gives me a head start, i guess.
