In GitHub - Daniil-Osokin/lightweight-human-pose-estimation.pytorch: Fast and accurate human pose estimation in PyTorch. Contains implementation of "Real-time 2D Multi-Person Pose Estimation on CPU: Lightweight OpenPose" paper., the open source project, there is a pre-trained pytorch model: checkpoint_iter_370000.pth, which I successfully converted to onnx and then moved on to the TensorRT engine.
During the conversion to the TensorRT engine, the terminal keeps returning warnings:
[07/17/2024-16:01:21] [TRT] [W] Unknown embedded device detected. Using 59660MiB as the allocation cap for memory on embedded devices.
What do I need to do to eliminate these warnings.
The code I converted the onnx model to the TensorRT engine is as follows:
import tensorrt as trt
import pycuda.driver as cuda
import pycuda.autoinit
TRT_LOGGER = trt.Logger(trt.Logger.WARNING)
def build_engine(onnx_file_path, engine_file_path):
with trt.Builder(TRT_LOGGER) as builder, builder.create_network(
1 << int(trt.NetworkDefinitionCreationFlag.EXPLICIT_BATCH)
) as network, trt.OnnxParser(network, TRT_LOGGER) as parser:
config = builder.create_builder_config()
config.set_memory_pool_limit(trt.MemoryPoolType.WORKSPACE, 1 << 30) # 1GB
with open(onnx_file_path, 'rb') as model:
if not parser.parse(model.read()):
for error in range(parser.num_errors):
print(parser.get_error(error))
return None
serialized_engine = builder.build_serialized_network(network, config)
with open(engine_file_path, "wb") as f:
f.write(serialized_engine)
def main():
onnx_file_path = “human-pose-estimation.onnx”
engine_file_path = “human-pose-estimation.trt”
print(“TensorRT engine has been built and saved to”, engine_file_path)
if name == “main”:
main()
