tf_node: name: “stack”
op: “Pack”
input: “stack/0_1”
input: “stack/1_1”
input: “stack/2”
input: “stack/3”
attr {
key: “N”
value {
i: 4
attr {
key: “T”
value {
type: DT_INT32
attr {
key: “_output_shapes”
value {
list {
shape {
dim {
dim {
attr {
key: “axis”
value {
i: 0
attr {
key: “value”
value {
File “uff_custom_plugin.py”, line 206, in
main()
File “uff_custom_plugin.py”, line 197, in main
uff_path = model_to_uff(MODEL_PATH)
File “uff_custom_plugin.py”, line 146, in model_to_uff
quiet=False
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/conversion_helpers.py”, line 132, in from_tensorflow
name=“main”)
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 78, in convert_tf2uff_graph
uff_graph, input_replacements)
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 65, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes)
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 44, in convert_layer
return cls.registry_[op](name, tf_node, inputs, uff_graph, **kwargs)
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/converter_functions.py”, line 270, in convert_conv2d
return _conv2d_helper(name, tf_node, inputs, uff_graph, func=“conv2d”, **kwargs)
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/converter_functions.py”, line 286, in _conv2d_helper
tf_node, inputs, kwargs[“tf_nodes”])
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 169, in apply_fused_padding
p = cls.convert_tf2numpy_const_node(tf_padding_node)
File “/home/tongbei/software/anaconda2/lib/python2.7/site-packages/uff/converters/tensorflow/converter.py”, line 152, in convert_tf2numpy_const_node
return array.reshape(shape)
ValueError: cannot reshape array of size 0 into shape ()
