Linux distro and version: Linux 16.04
GPU type: Geforce 1080
nvidia Driver Version: 384.130
CUDA version: release 9.0, V9.0.225
CUDNN version:7
Python version: 3.5
Tensorflow version:1.8.0
TensorRT version: 5.0.2.6
Describe the problem:
convert_to_uff.py failed to convert .pb to .uff.
command:
python3 /usr/local/lib/python3.5/dist-packages/uff/bin/convert_to_uff.py trainedweights.pb -p config.py
In config.py are unsupported customer layers. It seems like that I need to register these layers beforehand. But I don’t know how.
config.py:
import graphsurgeon as gs
import tensorflow as tf
import tensorrt as trt
TRT_LOGGER = trt.Logger()
trt.init_libnvinfer_plugins(TRT_LOGGER, '')
ROIAlignClassifier=gs.create_plugin_node(name="roi_align_classifier_TRT", op="roi_align_classifier_Plugin_TRT",
dtype=tf.float32,
pool_size=14,
image_shape=[448,448,3]
ROIAlignKpMask=gs.create_plugin_node(name="roi_align_kpmask_TRT", op="roi_align_kpmask_Plugin_TRT",
dtype=tf.float32,
pool_size=14,
mrcnn_keypoint_mask_upsample_2= gs.create_plugin_node(name="upsample_2_TRT", op="upsample_2_Plugin_TRT",
dtype=tf.float32,
mrcnn_keypoint_mask_upsample_1= gs.create_plugin_node(name="upsample_1_TRT", op="upsample_1_Plugin_TRT",
dtype=tf.float32,
fpn_p5upsampled= gs.create_plugin_node(name="upsample_5_TRT", op="upsample_5_Plugin_TRT",
dtype=tf.float32,
fpn_p4upsampled= gs.create_plugin_node(name="upsample_4_TRT", op="upsample_4_Plugin_TRT",
dtype=tf.float32,
fpn_p3upsampled= gs.create_plugin_node(name="upsample_3_TRT", op="upsample_3_Plugin_TRT",
dtype=tf.float32,
namespace_plugin_map = {
"roi_align_classifier": ROIAlignClassifier,
"roi_align_keypoint_mask": ROIAlignKpMask,
"fpn_p3upsampled":fpn_p3upsampled,
"fpn_p4upsampled":fpn_p4upsampled,
"fpn_p5upsampled":fpn_p5upsampled,
"mrcnn_keypoint_mask_upsample_1":mrcnn_keypoint_mask_upsample_1,
"mrcnn_keypoint_mask_upsample_2":mrcnn_keypoint_mask_upsample_2,
def preprocess(dynamic_graph):
# Now create a new graph by collapsing namespaces
dynamic_graph.collapse_namespaces(namespace_plugin_map)
# Remove the outputs, so we just have a single output node (NMS).
dynamic_graph.remove(dynamic_graph.graph_outputs, remove_exclusive_dependencies=False)
Error and warnings
Using output node mrcnn_prob/Sum
Converting to UFF graph
Warning: keepdims is ignored by the UFF Parser and defaults to True
Warning: No conversion function registered for layer: upsample_2_Plugin_TRT yet.
Converting upsample_2_TRT as custom op: upsample_2_Plugin_TRT
Warning: No conversion function registered for layer: upsample_1_Plugin_TRT yet.
Converting upsample_1_TRT as custom op: upsample_1_Plugin_TRT
Warning: No conversion function registered for layer: roi_align_kpmask_Plugin_TRT yet.
Converting roi_align_kpmask_TRT as custom op: roi_align_kpmask_Plugin_TRT
Warning: No conversion function registered for layer: upsample_5_Plugin_TRT yet.
Converting upsample_5_TRT as custom op: upsample_5_Plugin_TRT
Warning: No conversion function registered for layer: upsample_4_Plugin_TRT yet.
Converting upsample_4_TRT as custom op: upsample_4_Plugin_TRT
Warning: No conversion function registered for layer: upsample_3_Plugin_TRT yet.
Converting upsample_3_TRT as custom op: upsample_3_Plugin_TRT
File "/usr/local/lib/python3.5/dist-packages/uff/bin/convert_to_uff.py", line 93, in <module>
main()
File "/usr/local/lib/python3.5/dist-packages/uff/bin/convert_to_uff.py", line 89, in main
debug_mode=args.debug
File "/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 187, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 157, in from_tensorflow
debug_mode=debug_mode)
File "/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File "/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File "/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter.py", line 47, in convert_layer
return cls.registry_[op](name, tf_node, inputs, uff_graph, **kwargs)
File "/usr/local/lib/python3.5/dist-packages/uff/converters/tensorflow/converter_functions.py", line 410, in convert_strided_slice
raise ValueError("ellipsis_mask not supported")
ValueError: ellipsis_mask not supported
