Hi Experts
I am trying to run the sample “end-to-end tensorflow mnist” python. I have a model lenet5.pb and I need to run:
python convert_to_uff models/lenet5.pb
The file convert_to_uff is in my folder:
usr/lib/python3.6/dist-packages/uff/bin/
Do I need to copy the file or run:
python usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py models/lenet5.pb
What is the best way?
When I run the above statement I get an error:
python: can’t open file ‘usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py’: [Errno 2] No such file or directory
Thanks,
sojohan
It should be:
python /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py models/lenet5.pb
Hi Junytang
But then I got this error messages:
File “/usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py”, line 15, in
import uff
ModuleNotFoundError: No module named ‘uff’
Regards,
Sojohan
The path is within python3 and should be executed with python3:
<b>python3</b> /usr/lib/python3.6/dist-packages/uff/bin/convert_to_uff.py models/lenet5.pb
Hi AastaLLL
so far so good. But when I run the
python3 sample.py -d /usr/src/tensorrt/python/data/mnist/1.pgm
I get an error that pycuda is not installed.
I then use the following command:
python3 -m pip install -r requirements.txt
I get several pages of errors and the last part is below. Any hints?
running install_lib
creating /usr/local/lib/python3.6/dist-packages/pycuda
error: could not create ‘/usr/local/lib/python3.6/dist-packages/pycuda’: Permission denied
ERROR: Command “/usr/bin/python3 -u -c ‘import setuptools, tokenize;file=’”’"’/tmp/pip-install-sntio0hl/pycuda/setup.py’"’"’;f=getattr(tokenize, ‘"’"‘open’"’"’, open)(file);code=f.read().replace(’"’"’\r\n’"’"’, ‘"’"’\n’"’"’);f.close();exec(compile(code, file, ‘"’"‘exec’"’"’))’ install --record /tmp/pip-record-6zjn5eok/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-install-sntio0hl/pycuda/
sojohan
You can get pyCUDA installed with the following commands:
$ sudo apt-get install python3-pip libhdf5-serial-dev hdf5-tools
$ pip3 install pycuda --user
Hi AastaLLL
That worked I am now able to make predictions…
python3 sample.py
Thanks,
Sojohans
