Tensorflow version: 1.13.1
TensorRT Installation: TensorRT 5.1.5.0 GA for Ubuntu 16.04 and CUDA 10.0 tar package
Error:
Converting mobilenetv2_1.00_224/Conv_1_bn/cond/ReadVariableOp_1/Switch as custom op: Switch
<omitted>
uff_model = uff.from_tensorflow_frozen_model(pb_filepath)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 233, in from_tensorflow_frozen_model
return from_tensorflow(graphdef, output_nodes, preprocessor, **kwargs)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/conversion_helpers.py", line 181, in from_tensorflow
debug_mode=debug_mode)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 94, in convert_tf2uff_graph
uff_graph, input_replacements, debug_mode=debug_mode)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 79, in convert_tf2uff_node
op, name, tf_node, inputs, uff_graph, tf_nodes=tf_nodes, debug_mode=debug_mode)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 41, in convert_layer
fields = cls.parse_tf_attrs(tf_node.attr)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 222, in parse_tf_attrs
return {key: cls.parse_tf_attr_value(val) for key, val in attrs.items() if val is not None and val.WhichOneof('value') is not None}
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 222, in <dictcomp>
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 218, in parse_tf_attr_value
return cls.convert_tf2uff_field(code, val)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 190, in convert_tf2uff_field
return TensorFlowToUFFConverter.convert_tf2numpy_dtype(val)
File "/usr/local/lib/python2.7/dist-packages/uff/converters/tensorflow/converter.py", line 103, in convert_tf2numpy_dtype
return tf.as_dtype(dtype).as_numpy_dtype
File "/home/ikarakozis/.local/lib/python2.7/site-packages/tensorflow/python/framework/dtypes.py", line 129, in as_numpy_dtype
return _TF_TO_NP[self._type_enum]
KeyError: 20
Code:
import tensorflow as tf
tf.enable_v2_behavior()
def main():
with tf.Session() as sess:
model = tf.keras.applications.MobileNetV2(
input_shape=[224, 224, 3],
include_top=False,
weights='imagenet')
global_average_layer = tf.keras.layers.GlobalAveragePooling2D()
prediction_layer = tf.keras.layers.Dense(2, activation=act)
model = tf.keras.Sequential(
[model, global_average_layer, prediction_layer])
# get inference graph
graph_def = tf.graph_util.convert_variables_to_constants(sess, sess.graph_def, ['dense/Sigmoid'])
graph_def = tf.graph_util.remove_training_nodes(graph_def)
# write graph to .pb file
pb_filepath = 'saved_model.pb'
with open(pb_filepath, 'wb') as f:
f.write(graph_def.SerializeToString())
if __name__ == '__main__':
main()
