Hi there,
This is my first post, so apologies if I don’t provide all the right information first time round.
It is worth mentioning I have never used CUDA or OpenGL before so this is all new to me.
My high level issue is I am trying to take an OpenGL image frame and convert it into an OpenCV GpuMat for simple image processing. I then want to move this image back to an OpenGL format for display.
The OpenGL texture is provided to me.
It was defined as below
GLuint mCaptureTexture;
glEnable(GL_TEXTURE_2D);
glGenTextures(1, &mCaptureTexture);
glBindTexture(GL_TEXTURE_2D, mCaptureTexture);
As I need to keep the data in the GPU I found that the CUDA graphics interoperability functions should provide me the ability to do this. I am just struggling to understand how to do it.
Below is the process I was following:
cudaGraphicsResource_t texRes;
cudaGraphicsGLRegisterImage(&texRes, mCaptureTexture, GL_TEXTURE_2D, cudaGraphicsRegisterFlagsNone);
cudaGraphicsMapResources(1, &texRes, 0);
cudaArray* texArray;
cudaGraphicsSubResourceGetMappedArray(&texArray, texRes, 0, 0);
// Note: I am assuming that cudaGraphicsSubResourceGetMappedArray is the correct function to use. If not please advise.
Here is where I have been trying to get it into a GpuMat.
Suggestions on the web seem to indicate trying to use cudaMemcpyToArray or a another function.
cudaGraphicsUnmapResources(1, &texRes);
If someone could provide a simple example of a few lines on how to take the cudaArray and get it into a GpuMat, and also then how to get it back into OpenGL texture that would be great.
Thanks in advance.
