• V100
• DS5.0 Docker
• 7.0.0
• 440.64
Hi all, I am using the sample code from here, it works correctly when the batch size = 1, but for batch size != 1 it modifies only the first frame in a batch.
For example, for batch size = 4 it will modify only 0th, 4th and 8th frame while leaving the rest as they were.
I think that the problem is that NvBufSurfTransform will modify only the first frame and I could not find a way to tell it which frame I want to modify. Could someone provide an example how to modify all frames in a batch using NvBufSurfTransform or any other way?
Thanks,
Ruslan
