This is a C delaunay Code to Triangulate a sample of points.Here is its C implementation.I tried converting that to Cuda but that is taking more time than nornal C implementation.Can anyone help me on how to covert this C code to Cuda?
typedef struct {
int p1,p2,p3;
} ITRIANGLE;
typedef struct {
int p1,p2;
} IEDGE;
typedef struct {
double x,y,z;
} XYZ;
Triangulation subroutine
Takes as input NV vertices in array pxyz
Returned is a list of ntri triangular faces in the array v
These triangles are arranged in a consistent clockwise order.
The triangle array ‘v’ should be malloced to 3 * nv
The vertex array pxyz must be big enough to hold 3 more points
The vertex array must be sorted in increasing x values say
qsort(p,nv,sizeof(XYZ),XYZCompare);
int XYZCompare(void *v1,void *v2)
XYZ *p1,*p2;
p1 = v1;
p2 = v2;
if (p1->x < p2->x)
return(-1);
else if (p1->x > p2->x)
return(1);
else
return(0);
int Triangulate(int nv,XYZ *pxyz,ITRIANGLE *v,int *ntri)
int *complete = NULL;
IEDGE *edges = NULL;
int nedge = 0;
int trimax,emax = 200;
int status = 0;
int inside;
int i,j,k;
double xp,yp,x1,y1,x2,y2,x3,y3,xc,yc,r;
double xmin,xmax,ymin,ymax,xmid,ymid;
double dx,dy,dmax;
/* Allocate memory for the completeness list, flag for each triangle /
trimax = 4 * nv;
if ((complete = malloc(trimaxsizeof(int))) == NULL) {
status = 1;
goto skip;
/* Allocate memory for the edge list /
if ((edges = malloc(emax(long)sizeof(EDGE))) == NULL) {
status = 2;
goto skip;
Find the maximum and minimum vertex bounds.
This is to allow calculation of the bounding triangle
xmin = pxyz[0].x;
ymin = pxyz[0].y;
xmax = xmin;
ymax = ymin;
for (i=1;i<nv;i++) {
if (pxyz[i].x < xmin) xmin = pxyz[i].x;
if (pxyz[i].x > xmax) xmax = pxyz[i].x;
if (pxyz[i].y < ymin) ymin = pxyz[i].y;
if (pxyz[i].y > ymax) ymax = pxyz[i].y;
dx = xmax - xmin;
dy = ymax - ymin;
dmax = (dx > dy) ? dx : dy;
xmid = (xmax + xmin) / 2.0;
ymid = (ymax + ymin) / 2.0;
Set up the supertriangle
This is a triangle which encompasses all the sample points.
The supertriangle coordinates are added to the end of the
vertex list. The supertriangle is the first triangle in
the triangle list.
pxyz[nv+0].x = xmid - 20 * dmax;
pxyz[nv+0].y = ymid - dmax;
pxyz[nv+0].z = 0.0;
pxyz[nv+1].x = xmid;
pxyz[nv+1].y = ymid + 20 * dmax;
pxyz[nv+1].z = 0.0;
pxyz[nv+2].x = xmid + 20 * dmax;
pxyz[nv+2].y = ymid - dmax;
pxyz[nv+2].z = 0.0;
v[0].p1 = nv;
v[0].p2 = nv+1;
v[0].p3 = nv+2;
complete[0] = FALSE;
*ntri = 1;
Include each point one at a time into the existing mesh
for (i=0;i<nv;i++) {
xp = pxyz[i].x;
yp = pxyz[i].y;
nedge = 0;
Set up the edge buffer.
If the point (xp,yp) lies inside the circumcircle then the
three edges of that triangle are added to the edge buffer
and that triangle is removed.
for (j=0;j<(*ntri);j++) {
if (complete[j])
continue;
x1 = pxyz[v[j].p1].x;
y1 = pxyz[v[j].p1].y;
x2 = pxyz[v[j].p2].x;
y2 = pxyz[v[j].p2].y;
x3 = pxyz[v[j].p3].x;
y3 = pxyz[v[j].p3].y;
inside = CircumCircle(xp,yp,x1,y1,x2,y2,x3,y3,&xc,&yc,&r);
if (xc < xp && ((xp-xc)*(xp-xc)) > r)
complete[j] = TRUE;
if (inside) {
/* Check that we haven't exceeded the edge list size */
if (nedge+3 >= emax) {
emax += 100;
if ((edges = realloc(edges,emax*(long)sizeof(EDGE))) == NULL) {
status = 3;
goto skip;
edges[nedge+0].p1 = v[j].p1;
edges[nedge+0].p2 = v[j].p2;
edges[nedge+1].p1 = v[j].p2;
edges[nedge+1].p2 = v[j].p3;
edges[nedge+2].p1 = v[j].p3;
edges[nedge+2].p2 = v[j].p1;
nedge += 3;
v[j] = v[(*ntri)-1];
complete[j] = complete[(*ntri)-1];
(*ntri)--;
j--;
Tag multiple edges
Note: if all triangles are specified anticlockwise then all
interior edges are opposite pointing in direction.
for (j=0;j<nedge-1;j++) {
for (k=j+1;k<nedge;k++) {
if ((edges[j].p1 == edges[k].p2) && (edges[j].p2 == edges[k].p1)) {
edges[j].p1 = -1;
edges[j].p2 = -1;
edges[k].p1 = -1;
edges[k].p2 = -1;
/* Shouldn't need the following, see note above */
if ((edges[j].p1 == edges[k].p1) && (edges[j].p2 == edges[k].p2)) {
edges[j].p1 = -1;
edges[j].p2 = -1;
edges[k].p1 = -1;
edges[k].p2 = -1;
Form new triangles for the current point
Skipping over any tagged edges.
All edges are arranged in clockwise order.
for (j=0;j<nedge;j++) {
if (edges[j].p1 < 0 || edges[j].p2 < 0)
continue;
if ((*ntri) >= trimax) {
status = 4;
goto skip;
v[*ntri].p1 = edges[j].p1;
v[*ntri].p2 = edges[j].p2;
v[*ntri].p3 = i;
complete[*ntri] = FALSE;
(*ntri)++;
Remove triangles with supertriangle vertices
These are triangles which have a vertex number greater than nv
for (i=0;i<(*ntri);i++) {
if (v[i].p1 >= nv || v[i].p2 >= nv || v[i].p3 >= nv) {
v[i] = v[(*ntri)-1];
(*ntri)–;
i–;
skip:
free(edges);
free(complete);
return(status);
Return TRUE if a point (xp,yp) is inside the circumcircle made up
of the points (x1,y1), (x2,y2), (x3,y3)
The circumcircle centre is returned in (xc,yc) and the radius r
NOTE: A point on the edge is inside the circumcircle
int CircumCircle(double xp,double yp,
double x1,double y1,double x2,double y2,double x3,double y3,
double *xc,double *yc,double *rsqr)
double m1,m2,mx1,mx2,my1,my2;
double dx,dy,drsqr;
double fabsy1y2 = fabs(y1-y2);
double fabsy2y3 = fabs(y2-y3);
/* Check for coincident points */
if (fabsy1y2 < EPSILON && fabsy2y3 < EPSILON)
return(FALSE);
if (fabsy1y2 < EPSILON) {
m2 = - (x3-x2) / (y3-y2);
mx2 = (x2 + x3) / 2.0;
my2 = (y2 + y3) / 2.0;
*xc = (x2 + x1) / 2.0;
*yc = m2 * (*xc - mx2) + my2;
} else if (fabsy2y3 < EPSILON) {
m1 = - (x2-x1) / (y2-y1);
mx1 = (x1 + x2) / 2.0;
my1 = (y1 + y2) / 2.0;
*xc = (x3 + x2) / 2.0;
*yc = m1 * (*xc - mx1) + my1;
} else {
*xc = (m1 * mx1 - m2 * mx2 + my2 - my1) / (m1 - m2);
if (fabsy1y2 > fabsy2y3) {
} else {
dx = x2 - *xc;
dy = y2 - yc;
rsqr = dxdx + dydy;
dx = xp - xc;
dy = yp - yc;
drsqr = dxdx + dydy;
return((drsqr <= *rsqr) ? TRUE : FALSE);
