tao-converter -d 3,544,960 -k tao -o NMS frcnn_kitti_vgg16.etlt
log********
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:604] Reading dangerously large protocol message. If the message turns out to be larger than 2147483647 bytes, parsing will be halted for security reasons. To increase the limit (or to disable these warnings), see CodedInputStream::SetTotalBytesLimit() in google/protobuf/io/coded_stream.h.
[INFO] UFFParser: Did not find plugin field entry isBatchAgnostic in the Registered Creator for layer NMS
[INFO] UFFParser: Did not find plugin field entry scoreBits in the Registered Creator for layer NMS
[libprotobuf WARNING google/protobuf/io/coded_stream.cc:81] The total number of bytes read was 548370337
Killed
env :
JETSON NANO
jetpack 4.5.1
DeepStream 5.1
Tao 3.0.11.8
