I am trying to convert .h5 to .pb using the steps mentioned in:
Speeding up Deep Learning Inference Using TensorFlow, ONNX, and TensorRT | NVIDIA Developer Blog
But no .pb file is generated.
The code is as follows.
import tensorflow as tf
from tensorflow.compat.v1 import graph_util
from tensorflow.keras.models import Model
from tensorflow.python.keras import backend as K
from tensorflow.keras.models import load_model
import argparse
tf.compat.v1.disable_eager_execution()
K.set_learning_phase(0)
def keras_to_pb(model, output_filename, output_node_names):
This is the function to convert the Keras model to pb.
Args:
model: The Keras model.
output_filename: The output .pb file name.
output_node_names: The output nodes of the network. If None, then
the function gets the last layer name as the output node.
Get the names of the input and output nodes.
in_name = model.layers[0].get_output_at(0).name.split(‘:’)[0]
if output_node_names is None:
output_node_names = [model.layers[-1].get_output_at(0).name.split(‘:’)[0]]
sess = K.get_session()
The TensorFlow freeze_graph expects a comma-separated string of output node names.
output_node_names_tf = ‘,’.join(output_node_names)
frozen_graph_def = graph_util.convert_variables_to_constants(
sess,
sess.graph.as_graph_def(),
output_node_names)
sess.close()
wkdir = ‘’
tf.io.write_graph(frozen_graph_def, wkdir, output_filename, as_text=False)
return in_name, output_node_names
def main(args):
# load ResNet50 model pre-trained on imagenet
model = load_model(args.model_path)
# Convert keras ResNet50 model to .bp file
in_tensor_name, out_tensor_names = keras_to_pb(model, args.output_pb_file , None)
if name == ‘main’:
parser = argparse.ArgumentParser()
parser.add_argument(‘–model_path’, type=str, default=‘facenet_keras.h5’)
parser.add_argument(‘–output_pb_file’, type=str, default=‘facenet.pb’)
args=parser.parse_args()
main(args)
Error:
2021-06-22 15:24:25.221701: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcudart.so.11.0
/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/keras/backend.py:435: UserWarning: tf.keras.backend.set_learning_phase
is deprecated and will be removed after 2020-10-11. To update it, simply pass a True/False value to the training
argument of the __call__
method of your layer or model.
warnings.warn('tf.keras.backend.set_learning_phase
is deprecated and ’
2021-06-22 15:24:26.898438: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcuda.so.1
2021-06-22 15:24:26.955760: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:26.956356: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1733] Found device 0 with properties:
pciBusID: 0000:00:1e.0 name: Tesla T4 computeCapability: 7.5
coreClock: 1.59GHz coreCount: 40 deviceMemorySize: 14.75GiB deviceMemoryBandwidth: 298.08GiB/s
2021-06-22 15:24:26.956386: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcudart.so.11.0
2021-06-22 15:24:26.959579: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcublas.so.11
2021-06-22 15:24:26.959640: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcublasLt.so.11
2021-06-22 15:24:26.960701: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcufft.so.10
2021-06-22 15:24:26.960994: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcurand.so.10
2021-06-22 15:24:26.964340: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcusolver.so.11
2021-06-22 15:24:26.965160: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcusparse.so.11
2021-06-22 15:24:26.965364: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcudnn.so.8
2021-06-22 15:24:26.965448: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:26.966038: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:26.966589: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1871] Adding visible gpu devices: 0
WARNING:tensorflow:From /home/ubuntu/.local/lib/python3.6/site-packages/keras/layers/normalization.py:524: _colocate_with (from tensorflow.python.framework.ops) is deprecated and will be removed in a future version.
Instructions for updating:
Colocations handled automatically by placer.
2021-06-22 15:24:32.904480: I tensorflow/core/platform/cpu_feature_guard.cc:142] This TensorFlow binary is optimized with oneAPI Deep Neural Network Library (oneDNN) to use the following CPU instructions in performance-critical operations: AVX2 AVX512F FMA
To enable them in other operations, rebuild TensorFlow with the appropriate compiler flags.
2021-06-22 15:24:32.904888: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:32.905495: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1733] Found device 0 with properties:
2021-06-22 15:24:32.905588: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:32.906149: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:32.906693: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1871] Adding visible gpu devices: 0
2021-06-22 15:24:32.906746: I tensorflow/stream_executor/platform/default/dso_loader.cc:53] Successfully opened dynamic library libcudart.so.11.0
2021-06-22 15:24:33.515833: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1258] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-06-22 15:24:33.515872: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1264] 0
2021-06-22 15:24:33.515883: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1277] 0: N
2021-06-22 15:24:33.516045: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:33.516648: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:33.517203: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:33.517743: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1418] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 13803 MB memory) → physical GPU (device: 0, name: Tesla T4, pci bus id: 0000:00:1e.0, compute capability: 7.5)
2021-06-22 15:24:34.122337: I tensorflow/core/platform/profile_utils/cpu_utils.cc:114] CPU Frequency: 2499995000 Hz
WARNING:tensorflow:No training configuration found in the save file, so the model was not compiled. Compile it manually.
2021-06-22 15:24:36.638373: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:36.638726: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1733] Found device 0 with properties:
2021-06-22 15:24:36.638857: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:36.639260: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:36.639587: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1871] Adding visible gpu devices: 0
2021-06-22 15:24:36.639628: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1258] Device interconnect StreamExecutor with strength 1 edge matrix:
2021-06-22 15:24:36.639641: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1264] 0
2021-06-22 15:24:36.639653: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1277] 0: N
2021-06-22 15:24:36.639756: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:36.640099: I tensorflow/stream_executor/cuda/cuda_gpu_executor.cc:937] successful NUMA node read from SysFS had negative value (-1), but there must be at least one NUMA node, so returning NUMA node zero
2021-06-22 15:24:36.640407: I tensorflow/core/common_runtime/gpu/gpu_device.cc:1418] Created TensorFlow device (/job:localhost/replica:0/task:0/device:GPU:0 with 13803 MB memory) → physical GPU (device: 0, name: Tesla T4, pci bus id: 0000:00:1e.0, compute capability: 7.5)
WARNING:tensorflow:From /home/ubuntu/sayanti/tf2trt_with_onnx/keras_to_pb_tf2.py:37: convert_variables_to_constants (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Use tf.compat.v1.graph_util.convert_variables_to_constants
WARNING:tensorflow:From /home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/framework/convert_to_constants.py:857: extract_sub_graph (from tensorflow.python.framework.graph_util_impl) is deprecated and will be removed in a future version.
Use tf.compat.v1.graph_util.extract_sub_graph
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/client/session.py”, line 1375, in _do_call
return fn(*args)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/client/session.py”, line 1360, in _run_fn
target_list, run_metadata)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/client/session.py”, line 1453, in _call_tf_sessionrun
run_metadata)
tensorflow.python.framework.errors_impl.FailedPreconditionError: 2 root error(s) found.
(0) Failed precondition: Could not find variable Block17_5_Branch_0_Conv2d_1x1_BatchNorm/moving_variance. This could mean that the variable has been deleted. In TF1, it can also mean the variable is uninitialized. Debug info: container=localhost, status=Not found: Container localhost does not exist. (Could not find resource: localhost/Block17_5_Branch_0_Conv2d_1x1_BatchNorm/moving_variance)
[[{{node Block17_5_Branch_0_Conv2d_1x1_BatchNorm/moving_variance/Read/ReadVariableOp}}]]
[[Block17_10_Branch_1_Conv2d_0c_7x1/kernel/Read/ReadVariableOp/_25]]
(1) Failed precondition: Could not find variable Block17_5_Branch_0_Conv2d_1x1_BatchNorm/moving_variance. This could mean that the variable has been deleted. In TF1, it can also mean the variable is uninitialized. Debug info: container=localhost, status=Not found: Container localhost does not exist. (Could not find resource: localhost/Block17_5_Branch_0_Conv2d_1x1_BatchNorm/moving_variance)
0 successful operations.
0 derived errors ignored.
During handling of the above exception, another exception occurred:
File “conv.py”, line 14, in
input_name, output_node_names = keras_to_pb(model, PB_FILE_PATH, None)
File “/home/ubuntu/sayanti/tf2trt_with_onnx/keras_to_pb_tf2.py”, line 37, in keras_to_pb
output_node_names)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/util/deprecation.py”, line 337, in new_func
return func(*args, **kwargs)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/framework/graph_util_impl.py”, line 281, in convert_variables_to_constants
variable_names_denylist=variable_names_blacklist)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/framework/convert_to_constants.py”, line 1165, in convert_variables_to_constants_from_session_graph
variable_names_denylist=variable_names_denylist))
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/framework/convert_to_constants.py”, line 876, in init
converted_tensors = session.run(tensor_names_to_convert)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/client/session.py”, line 968, in run
run_metadata_ptr)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/client/session.py”, line 1191, in _run
feed_dict_tensor, options, run_metadata)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/client/session.py”, line 1369, in _do_run
run_metadata)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/client/session.py”, line 1394, in _do_call
raise type(e)(node_def, op, message)
[[node Block17_5_Branch_0_Conv2d_1x1_BatchNorm/moving_variance/Read/ReadVariableOp (defined at /home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/base_layer_utils.py:127) ]]
Original stack trace for ‘Block17_5_Branch_0_Conv2d_1x1_BatchNorm/moving_variance/Read/ReadVariableOp’:
File “conv.py”, line 13, in
model = load_model(MODEL_PATH)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/saving/save.py”, line 202, in load_model
compile)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/saving/hdf5_format.py”, line 181, in load_model_from_hdf5
custom_objects=custom_objects)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/saving/model_config.py”, line 59, in model_from_config
return deserialize(config, custom_objects=custom_objects)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/layers/serialization.py”, line 163, in deserialize
printable_module_name=‘layer’)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/utils/generic_utils.py”, line 672, in deserialize_keras_object
list(custom_objects.items())))
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/training.py”, line 2332, in from_config
functional.reconstruct_from_config(config, custom_objects))
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/functional.py”, line 1284, in reconstruct_from_config
process_node(layer, node_data)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/functional.py”, line 1232, in process_node
output_tensors = layer(input_tensors, **kwargs)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/base_layer_v1.py”, line 745, in call
self._maybe_build(inputs)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/base_layer_v1.py”, line 2066, in _maybe_build
self.build(input_shapes)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/layers/normalization.py”, line 451, in build
experimental_autocast=False)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/base_layer_v1.py”, line 440, in add_weight
caching_device=caching_device)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/training/tracking/base.py”, line 815, in _add_variable_with_custom_getter
**kwargs_for_getter)
File “/home/ubuntu/.local/lib/python3.6/site-packages/keras/engine/base_layer_utils.py”, line 127, in make_variable
shape=variable_shape if variable_shape else None)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/variables.py”, line 260, in call
return cls._variable_v1_call(*args, **kwargs)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/variables.py”, line 221, in _variable_v1_call
shape=shape)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/variables.py”, line 199, in
previous_getter = lambda **kwargs: default_variable_creator(None, **kwargs)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/variable_scope.py”, line 2626, in default_variable_creator
shape=shape)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/variables.py”, line 264, in call
return super(VariableMetaclass, cls).call(*args, **kwargs)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/resource_variable_ops.py”, line 1595, in init
distribute_strategy=distribute_strategy)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/resource_variable_ops.py”, line 1777, in _init_from_args
value = gen_resource_variable_ops.read_variable_op(handle, dtype)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/ops/gen_resource_variable_ops.py”, line 485, in read_variable_op
“ReadVariableOp”, resource=resource, dtype=dtype, name=name)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/framework/op_def_library.py”, line 750, in _apply_op_helper
attrs=attr_protos, op_def=op_def)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/framework/ops.py”, line 3565, in _create_op_internal
op_def=op_def)
File “/home/ubuntu/.local/lib/python3.6/site-packages/tensorflow/python/framework/ops.py”, line 2045, in init
self._traceback = tf_stack.extract_stack_for_node(self._c_op)
